One of the detector groups wants to use a Weiner power supply, model Floating Power Supply PL500-F8, connected via CAN bus. CAN bus is new for us. I looked on the EPICS web pages and noted that support was available for the Tew TIP810 CAN bus interface using the IP slot on an MVME162 or MVME172. We use MVME2301 and MVME2304 boards. Has anyone attempted to use the TIP810 on a PPC board? Any idea how hard this might be to implement? The alternative is to use an EPICS supported IPAC card. This would be the more expensive solution in terms of equipment. Is the TIP810 the only EPICS support CAN bus interface? Is a CAN bus controller that plugs directly into the VME bus a better option? The run from the CAN bus interface to the the power supply is about 100 feet. Will this distance have an impact on operations? Thanks Geoff
ANJ, 10 Aug 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
