1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAN bus and PPC processors
To: Geoff Savage <[email protected]>, tech-talk <[email protected]>
Date: Wed, 15 Jan 2003 15:09:35 -0600
Hi Geoff
Geoff Savage wrote:
Has anyone
attempted to use the TIP810 on a PPC board? Any idea how hard this
might be to implement?
It would be very hard. Motorola PPC boards don't have IP slots :)
> The alternative is to use an EPICS supported
IPAC card. This would be the more expensive solution in terms of equipment.
The SBS VIPC616 IP carrier card is ~ $500, so it's not too expensive. There are issues with this card concerning interrupt daisy chaining. We always put them on the right hand side of the crate for this reason. People who use the hytec carrier seem very happy with it. That one costs ~ $1100 though.
I know that Gemini use a PPC with a SBS carrier that has 4 TIP810s on. Last I knew this was working fine.
Is a CAN bus controller that plugs directly into the VME bus a better
option?
It always used to be more expensive. I don't know what's on the market now though.
The run from the CAN bus interface to the the power supply is about 100
feet.  Will this distance have an impact on operations?
IIRC > 40m will limit it to 500 kbps, so you may get away with 1 Mbps, but check the CAN spec.
John.
CAN bus and PPC processors Geoff Savage
Prev: Re: Where is caput? Ben-chin K. Cha
Next: EPICS exmaple application problem M.C.Shao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CAN bus and PPC processors Geoff Savage
