1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: R3.14.1 ioc example
To: Till Straumann <[email protected]>
Cc: "Kevin M. Peterson" <[email protected]>, tech-talk <[email protected]>
Date: Mon, 27 Jan 2003 17:39:23 -0600
Till Straumann wrote:
You have to set LD_LIBRARY_PATH when _running_, not when compiling
the 'example' application.
Good point.
Under LINUX, in order to embed the library path into the executable, you have to
1) either use the -rpath option to the linker
2) set LD_RUN_PATH when linking (note the difference: LD_RUN_PATH
is evaluated by the linker, LD_LIBRARY_PATH by the runtime linker,
i.e. when executing the linked application)
Note that setting the SHRLIB_SEARCH_DIRS variable adds the necessary -rpath options. It has only been implemented on Linux though - we should probably do the same thing on all Unix class OSs, but I believe Linux is currently the only OS where we build and use shared libraries by default. I don't like having a manual setting, but some sites need to be able to use different paths at build time and run-time.
- Andrew
A: No, see http://www.netmeister.org/news/learn2quote.html
Q: Should I include quotations after my reply ?
R3.14.1 ioc example Kevin M. Peterson
Re: R3.14.1 ioc example Till Straumann
Prev: Re: R3.14.1 ioc example Till Straumann
Next: Tornado II on HP-UX11.0 kabe
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
