1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: snc/seq enhancements ... local-variable access
To: <[email protected]>
Cc: "Laznovsky, Michael" <[email protected]>
Date: Tue, 4 Apr 2006 00:00:38 -0700
Greetings EPICS fans- I'm sending this email to solicit suggestions and comments
for some snc/seq enhancements I'm working on, in this case support for access to
local variables within sequence code.
Access is provided by show/get/put functions, and also via special PVs when a
small database is added to the IOC.  Progress thus far includes snc producing
the required data structures and the aformentioned seq functions.  For example,
the following illustrates a set of declarations in a source file and the output
of a series of "seqVarShow" calls:
	char         errmsg[256];
	char        *pbuf;
	char        *pbuf2;
	short        n;
	int          xyz[5][10];
	unsigned int m;
	long         foo;
	float        a;
	double       z;
Get thread ID:
	epics> seqShow
	Program Name     Thread ID  Thread Name      SS Name
	zz99Control      1e7a80     zz99seq          zz99_ctrl
"seqVarShow" with no arguments displays all local variables in all state
programs (or you can provide the thread id as an argument to limit output):
	epics> seqVarShow
	Program: zz99Control
	  Name                  Type            [n][n]  Address Value
	  errmsg                char            [256]   1e5334  "0"
	  pbuf                  char *                  1e5434  (NULL)
	  pbuf2                 char *                  1e5438  192270 -> "90 0 34 ..."
	  n                     short                   1e5448  "-77"
	  xyz                   int             [5][10] 1e5536  "3"
	  m                     unsigned int            1e544c  "1"
	  foo                   long                    1e5330  "0"
	  a                     float                   1e543c  "1.0"
	  z                     double                  1e5328  "0.1873811581904769"
"seqVarGet" with thread ID and variable name displays just that variable:
	epics> seqVarGet 1e7a80,"z"
	"0.9685835438816328"
"seqVarPut" with thread ID, variable name, and value (as string) modifies
the variable:
	epics> seqVarPut 1e7a80,"m","33"
	epics> seqVarGet 1e7a80,"m"
	"33"
Things to note (all preliminary at this point):
Both reentrant and non-reentrant cases are properly handled.
Variables of type "pointer" are resolved, so that the objects pointed to are
get/put, rather than the pointers themselves (unless the pointer is NULL).
Maybe provide a way to alter the pointer itself?
Character arrays (strings) are displayed/entered as numeric byte sequences
(could be selectable?).
Need a general way to get at arbitrary array elements.  Currently only the
first element is accessible.
While local variables are file-scoped (and thus shared by all state sets within
a given source file) the only way I see to uniquely identify a collection of
them is via a "thread ID"... "program name", "thread name", and "SS name"
are all potentially subject to collisions when multiple sequences are loaded
and/or invoked.
Short-term future plans include database and EDM display infrastructure to support
run-time debugging of state programs, including state single-stepping and forced
out-of-order transitions.
Feedback welcomed.
Mike
Re: snc/seq enhancements ... local-variable access Tim Mooney
Re: snc/seq enhancements ... local-variable access J. Lewis Muir
Prev: EPICS Training Course, Cambridge, England. July 2006 Philip Taylor
Next: RE: snc/seq enhancements ... local-variable access Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: snc/seq enhancements ... local-variable access Tim Mooney
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
