Hi, Mike.
A feature I would like is for snc to not generate warning messages for
variables that are defined in other included source files. For example:
Warning: variable "asynSuccess" is used but not declared.
I get this message at compile time if I'm using the asyn module and want
to check the return status of an asyn function call from the SNL
program. asynSuccess is defined as an asynStatus enum value in
asynDriver.h which I have included in my SNL program.
These warnings are common when defines or enums or whatever are defined
in other files and one wants to reference them from the SNL program.
Similarly, I'd like to be able to use defines for declaring SNL char
arrays. For example, it would be great if I could have a file color.h
that has
#define MAX_COLOR_NAME_SIZE 21
and then in the SNL program be able to do
char colorName[MAX_COLOR_NAME_SIZE];
This allows me to have the SNL program and other C code make use of this
MAX_COLOR_NAME_SIZE define so that it can be defined in just one place.
And lastly, I'd like it if SNL supported a "void *" declaration type so
that one could declare generic pointers rather than using "char *" for this.
Thanks for all your work on snc/seq!
-lewis
Laznovsky, Michael wrote:
Greetings EPICS fans- I'm sending this email to solicit suggestions and comments
for some snc/seq enhancements I'm working on, in this case support for access to
local variables within sequence code.
Access is provided by show/get/put functions, and also via special PVs when a
small database is added to the IOC. Progress thus far includes snc producing
the required data structures and the aformentioned seq functions. For example,
the following illustrates a set of declarations in a source file and the output
of a series of "seqVarShow" calls:
char errmsg[256];
char *pbuf;
char *pbuf2;
short n;
int xyz[5][10];
unsigned int m;
long foo;
float a;
double z;
Get thread ID:
epics> seqShow
Program Name Thread ID Thread Name SS Name
zz99Control 1e7a80 zz99seq zz99_ctrl
"seqVarShow" with no arguments displays all local variables in all state
programs (or you can provide the thread id as an argument to limit output):
epics> seqVarShow
Program: zz99Control
Name Type [n][n] Address Value
errmsg char [256] 1e5334 "0"
pbuf char * 1e5434 (NULL)
pbuf2 char * 1e5438 192270 -> "90 0 34 ..."
n short 1e5448 "-77"
xyz int [5][10] 1e5536 "3"
m unsigned int 1e544c "1"
foo long 1e5330 "0"
a float 1e543c "1.0"
z double 1e5328 "0.1873811581904769"
"seqVarGet" with thread ID and variable name displays just that variable:
epics> seqVarGet 1e7a80,"z"
"0.9685835438816328"
"seqVarPut" with thread ID, variable name, and value (as string) modifies
the variable:
epics> seqVarPut 1e7a80,"m","33"
epics> seqVarGet 1e7a80,"m"
"33"
Things to note (all preliminary at this point):
Both reentrant and non-reentrant cases are properly handled.
Variables of type "pointer" are resolved, so that the objects pointed to are
get/put, rather than the pointers themselves (unless the pointer is NULL).
Maybe provide a way to alter the pointer itself?
Character arrays (strings) are displayed/entered as numeric byte sequences
(could be selectable?).
Need a general way to get at arbitrary array elements. Currently only the
first element is accessible.
While local variables are file-scoped (and thus shared by all state sets within
a given source file) the only way I see to uniquely identify a collection of
them is via a "thread ID"... "program name", "thread name", and "SS name"
are all potentially subject to collisions when multiple sequences are loaded
and/or invoked.
Short-term future plans include database and EDM display infrastructure to support
run-time debugging of state programs, including state single-stepping and forced
out-of-order transitions.
Feedback welcomed.
Mike
- Re: snc/seq enhancements ... local-variable access Benjamin Franksen
- snc/seq enhancements ... local-variable access Laznovsky, Michael
Re: snc/seq enhancements ... local-variable access Tim Mooney
<2006>
2025
<2006>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
