1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: snc/seq enhancements ... local-variable access
To: [email protected]
Date: Tue, 4 Apr 2006 18:46:14 +0200
On Tuesday 04 April 2006 17:43, J. Lewis Muir wrote:
> A feature I would like is for snc to not generate warning messages
> for variables that are defined in other included source files. For
> example:
>    Warning:  variable "asynSuccess" is used but not declared.
> I get this message at compile time if I'm using the asyn module and
> want to check the return status of an asyn function call from the SNL
> program. asynSuccess is defined as an asynStatus enum value in
> asynDriver.h which I have included in my SNL program.
> These warnings are common when defines or enums or whatever are
> defined in other files and one wants to reference them from the SNL
> program.
This is probably going to be difficult. It would mean snc must parse all
the header files that are included. However, snc does not contain a
full-flegded C parser: it recognizes only a small subset of C.
Particularly, it cannot (IIRC) parse any C declarations.
> Similarly, I'd like to be able to use defines for declaring SNL char
> arrays. For example, it would be great if I could have a file color.h
> that has
>    #define MAX_COLOR_NAME_SIZE 21
> and then in the SNL program be able to do
>    char colorName[MAX_COLOR_NAME_SIZE];
> This allows me to have the SNL program and other C code make use of
> this MAX_COLOR_NAME_SIZE define so that it can be defined in just one
> place.
Provided your header file does only contain SNL constructs and cpp
instructions (#define, #include, etc.), this should be possible right
now, by preprocessing the source (with cpp) before compiling with snc.
Ben
Re: snc/seq enhancements ... local-variable access Eric Norum
snc/seq enhancements ... local-variable access Laznovsky, Michael
Re: snc/seq enhancements ... local-variable access J. Lewis Muir
Prev: Re: snc/seq enhancements ... local-variable access J. Lewis Muir
Next: ld error: Module contains undefined symbol(s) and may be unusable. Porter, Rodney R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: snc/seq enhancements ... local-variable access Eric Norum
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
