It would be nice to get the results of each of these calls in arrays of data. If the access calls and the reporting are separate - it's already done. When will this be available?
It is exactly what is needed to implement redundancy.
If you could add the ability to disable the sequencer and set the state externally, it is everything.
Bob
-----Original Message-----
From: Laznovsky, Michael [mailto:[email protected]]
Sent: Tuesday, April 04, 2006 12:01 AM
To: [email protected]
Cc: Laznovsky, Michael
Subject: snc/seq enhancements ... local-variable access
Greetings EPICS fans- I'm sending this email to solicit suggestions and comments for some snc/seq enhancements I'm working on, in this case support for access to local variables within sequence code.
Access is provided by show/get/put functions, and also via special PVs when a small database is added to the IOC. Progress thus far includes snc producing the required data structures and the aformentioned seq functions. For example, the following illustrates a set of declarations in a source file and the output of a series of "seqVarShow" calls:
char errmsg[256];
char *pbuf;
char *pbuf2;
short n;
int xyz[5][10];
unsigned int m;
long foo;
float a;
double z;
Get thread ID:
epics> seqShow
Program Name Thread ID Thread Name SS Name
zz99Control 1e7a80 zz99seq zz99_ctrl
"seqVarShow" with no arguments displays all local variables in all state programs (or you can provide the thread id as an argument to limit output):
epics> seqVarShow
Program: zz99Control
Name Type [n][n] Address Value
errmsg char [256] 1e5334 "0"
pbuf char * 1e5434 (NULL)
pbuf2 char * 1e5438 192270 -> "90 0 34 ..."
n short 1e5448 "-77"
xyz int [5][10] 1e5536 "3"
m unsigned int 1e544c "1"
foo long 1e5330 "0"
a float 1e543c "1.0"
z double 1e5328 "0.1873811581904769"
"seqVarGet" with thread ID and variable name displays just that variable:
epics> seqVarGet 1e7a80,"z"
"0.9685835438816328"
"seqVarPut" with thread ID, variable name, and value (as string) modifies the variable:
epics> seqVarPut 1e7a80,"m","33"
epics> seqVarGet 1e7a80,"m"
"33"
Things to note (all preliminary at this point):
Both reentrant and non-reentrant cases are properly handled.
Variables of type "pointer" are resolved, so that the objects pointed to are get/put, rather than the pointers themselves (unless the pointer is NULL).
Maybe provide a way to alter the pointer itself?
Character arrays (strings) are displayed/entered as numeric byte sequences (could be selectable?).
Need a general way to get at arbitrary array elements. Currently only the first element is accessible.
While local variables are file-scoped (and thus shared by all state sets within a given source file) the only way I see to uniquely identify a collection of them is via a "thread ID"... "program name", "thread name", and "SS name"
are all potentially subject to collisions when multiple sequences are loaded and/or invoked.
Short-term future plans include database and EDM display infrastructure to support run-time debugging of state programs, including state single-stepping and forced out-of-order transitions.
Feedback welcomed.
Mike
snc/seq enhancements ... local-variable access Laznovsky, Michael
Re: snc/seq enhancements ... local-variable access Tim Mooney
<2006>
2025
Re: snc/seq enhancements ... local-variable access Benjamin Franksen
RE: snc/seq enhancements ... local-variable access Chestnut, Ronald P.
<2006>
2025
