1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: snc/seq enhancements ... local-variable access
To: [email protected]
Date: Tue, 4 Apr 2006 21:05:33 +0200
On Tuesday 04 April 2006 19:41, Eric Norum wrote:
> I think that it would be good enough to simply remove the warning
> message.  If the token in question is in fact undefined the C
> compiler will report this.   Since snc emits appropriate '#line'
> directives the resulting error message will refer to the correct
> source line.
Yes, that would be good.
> On Apr 4, 2006, at 11:46 AM, Benjamin Franksen wrote:
> > On Tuesday 04 April 2006 17:43, J. Lewis Muir wrote:
> >> A feature I would like is for snc to not generate warning messages
> >> for variables that are defined in other included source files. For
> >> example:
> >>    Warning:  variable "asynSuccess" is used but not declared.
> >> I get this message at compile time if I'm using the asyn module
> >> and want to check the return status of an asyn function call from
> >> the SNL program. asynSuccess is defined as an asynStatus enum
> >> value in asynDriver.h which I have included in my SNL program.
> >> These warnings are common when defines or enums or whatever are
> >> defined in other files and one wants to reference them from the
> >> SNL program.
> > This is probably going to be difficult. It would mean snc must
> > parse all
> > the header files that are included. However, snc does not contain a
> > full-flegded C parser: it recognizes only a small subset of C.
> > Particularly, it cannot (IIRC) parse any C declarations.
Ben
snc/seq enhancements ... local-variable access Laznovsky, Michael
Re: snc/seq enhancements ... local-variable access Benjamin Franksen
Re: snc/seq enhancements ... local-variable access Eric Norum
Prev: RE: snc/seq enhancements ... local-variable access Chestnut, Ronald P.
Next: EpicsHostArch.pl for Intel OS X machines? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: snc/seq enhancements ... local-variable access Eric Norum
Next: RE: snc/seq enhancements ... local-variable access Dalesio, Leo `Bob`
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
