John,
Create you own menuScan.dbd in your ${MY_DIRECTORY}/dbd directory.
Then edit the makefile in your driver source and add a new USR_DBDFLAGS
directive.
# Used by dbExpand to look for dbd files
USR_DBDFLAGS += -I ${MY_DIRECTORY}/dbd
USR_DBDFLAGS += -I ${EPICS_BASE}/dbd
Note that the order of the directories is important.
Emmanuel
On Wed, 2006-04-05 at 11:25 -0500, Andrew Johnson wrote:
> john sinclair wrote:
> > What's the correct file to edit to add a scan period. I have narrowed things
> > down to the following two:
> > ...base/dbd/menuScan.dbd
> > ...base/src/db/menuScan.dbd
> The base/dbd directory is the install location where the file from
> src/db gets installed to, so you don't want to edit anything inside
> base/dbd or your changes will be lost when you next rebuild base.
> Note however that you can also override the scan periods in an IOC
> application by just providing your own modified copy of menuScan.dbd,
> which will be found before the base one.
> - Andrew
Emmanuel Mayssat
Cell: 650/793-0626
Lyncean Technologies, Inc.
"See the invisible"
- Re: adding a scan period Andrew Johnson
- adding a scan period john sinclair
<2006>
2025
<2006>
2025
