1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: adding a scan period
To: Emmanuel Mayssat <[email protected]>
Cc: john sinclair <[email protected]>, tech talk <[email protected]>
Date: Wed, 05 Apr 2006 13:19:44 -0500
Emmanuel Mayssat wrote:
John,
Create you own menuScan.dbd in your ${MY_DIRECTORY}/dbd directory.
Then edit the makefile in your driver source and add a new USR_DBDFLAGS
directive.
# Used by dbExpand to look for dbd files
USR_DBDFLAGS += -I ${MY_DIRECTORY}/dbd
USR_DBDFLAGS += -I ${EPICS_BASE}/dbd
Actually you don't even need to do this, just add this line to your xxxApp/src/Makefile in the directory where you put the modified menuScan.dbd file:
DBD += menuScan.dbd
This will ensure that the file gets installed to $(TOP)/dbd. In the DBD file expansion process the directory $(TOP)/dbd is always searched before $(EPICS_BASE)/dbd so it will find your version first.
Make sure that you do a 'make rebuild' after adding that line though.
- Andrew
There is no S in exprexxo.
adding a scan period john sinclair
Re: adding a scan period Andrew Johnson
Re: adding a scan period Emmanuel Mayssat
Prev: Re: adding a scan period Emmanuel Mayssat
Next: scan periods john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
