1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Upcoming ASYN release
To: TECHTALK tech-talk <[email protected]>
Cc: Tim Mooney <[email protected]>, Mark Rivers <[email protected]>
Date: Tue, 7 Nov 2006 08:48:17 -0600
Tim Mooney suggested that it's time for a new version of ASYN to be released. If you have any outstanding changes please let Tim, Mark Rivers, or me know about them so we can commit them.
Here are the current entries in the release notes for R4-7:
devGpib
Fixed error in GPIBACMD operations.
linuxGpib
Patches from Gasper Jansa to improve option handling.
devEpics
Fixed null pointer dereference for all device support when SCAN=I/O Intr and asyn port could not be found.
asynRecord
Fixed buffer overflow error when NRRD>40 and IFMT=ASCII.
asynGpib
Read method now sets return status and *eomReason properly.
drvAsynIPPort/drvAsynSerialPort
*eomReason now set to ASYN_EOM_CNT when read count has been satisfied.
Add support for UDP broadcasts. Specify "UDP*" and the network broadcast address in the port configuration command:
drvAsynIPPortConfigure("L0", "192.168.1.255:1234 UDP*", 0, 0, 0)
drvAsynSerialPort
Full support for new timeout semantics (timeout<0 means "wait forever for characters to arrive", timeout=0 means "return characters immediately available", timeout>0 means "return a timeout status if no characters are received within the specified number of seconds").
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Prev: Re: AAI/AAO database information Andrew Johnson
Next: Re: ant problem when building Irmis Lecorche Eric
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Support for Strings in database records.... David Dudley
Next: channel access client performance and gateway Rowland, J (James)
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
