Thanks to your help, I was so able to perform the "ant deploy" for the db directory ; to achieve properly that, I had to add the jce.jar and xml-apis.jar into the build.xml file Now the problem comes for the apps directory, when running there "ant deploy" first I get the following error messages : /compile: [javac] Compiling 107 source files to /home/epics1/Irmis/irmisBase/apps/build/classes [javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/DummySSLSocketFactory.java:7: error: ne peut repérer le package par défaut « javax.net.ssl ». Vérifier la variable d'environnement CLASSPATH et l'accès aux archives. [javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:12: error: Superinterface `CallbackHandler' of class `gov.anl.aps.irmis.login.SimpleCallbackHandler' not found. [javac] public class SimpleCallbackHandler implements CallbackHandler { [javac] ^ [javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:22: error: Type `Callback' not found in the declaration of the argument `callbacks' of method `handle'. [javac] public void handle(Callback[] callbacks) [javac] ^ [javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:23: error: Class `UnsupportedCallbackException' not found in `throws'. [javac] throws IOException, UnsupportedCallbackException { [javac] ^ [javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:33: error: Type `NameCallback' not found in the declaration of the local variable `nc'. [javac] NameCallback nc = (NameCallback)callbacks[i]; [javac] ^ [javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:41: error: Type `PasswordCallback' not found in the declaration of the local variable `pc'. [javac] PasswordCallback pc = (PasswordCallback)callbacks[i]; [javac] ^ [javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/PersonRoleLoginModule.java:27: error: Superinterface `LoginModule' of class `gov.anl.aps.irmis.login.PersonRoleLoginModule' not found. [javac] public class PersonRoleLoginModule implements LoginModule {/ [... may other errors ...] /[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/apps/pv/cfw/PVWindow.java:0: internal compiler error: Erreur de segmentation [javac] SVP soumettre un rapport complet d'anomalies, [javac] avec le source pré-traité si cela est approprié. [javac] Consulter <URL:http://bugzilla.redhat.com/bugzilla/> pour les instructions. / So I imagined to do the same as for the db directory : we found that the javax.net.ssl package was in the jsse.jar file and I added the path to this jar file. Therefore, I get the following errors c/ompile: [javac] Compiling 107 source files to /home/epics1/Irmis/irmisBase/apps/build/classes [javac] /home/epics1/Irmis/irmisBase/apps/src/CFWDemo/DemoDocument.java:0: error: archive .zip mal composée dans CLASSPATH: /usr/java/jre/lib/jsse.jar/ [javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/DummySSLSocketFactory.java:7: error: ne peut repérer le package par défaut « javax.net.ssl ». Vérifier la variable d'environnement CLASSPATH et l'accès aux archives. [javac] /home/epics1/Irmis/irmisBase/apps/src /[... same errors as in the first case ... ] So first it does not solve the problem (javax.net.ssl is no longer found) and furthermore a new error occurs telling that "the archive .zip is badly organized into /usr/java/jre/lib/jsse.jar"). As I didn't find anything concerning this error and not being a Java expert, I don't manage to go further at this point ... Any new idea to help me to get out from this ? Thanks in advance Eric begin:vcard fn;quoted-printable:Eric L=C3=A9corch=C3=A9 n;quoted-printable:L=C3=A9corch=C3=A9;Eric org:Ganil;Groupe Informatique Machine adr:;;BP 55027;Caen;;14076;France email;internet:[email protected] title:DBA / resp. GMAO / CC Ganil tel;work:02 31 45 47 35 tel;fax:02 31 45 47 28 url:http://www.ganil.fr version:2.1 end:vcard
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
