1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics / fpga
To: "D. Peter Siddons" <[email protected]>
Cc: [email protected], Joze Dedic <[email protected]>, [email protected]
Date: Fri, 02 Mar 2007 12:58:37 -0800
I was dumbfounded when I saw linux on a FPGA.
It was at the last NOBUGS conference.
Here is the abstract and contact.
Jonah M. Weber
Organization:
Lawrence Berkeley National Lab
Authors:
J. M. Weber and M. J. Chin
Session:
Data Acquisition and Controls (II)
(Wednesday morning)
Title:
Using FPGAs with Embedded Processors
for Complete Hardware and Software
Systems
Field Programmable Gate Arrays
(FPGAs) with embedded processors
allow the instrumentation designer
to field a system that tightly
couples high speed (>500MHz) digital
logic to a Control Systems-friendly
software platform (i.e. Linux,
VxWorks, EPICs). This technology
merges CPU and I/O functions onto a
single board allowing greater
flexibility in physical form factor,
power requirements, and data
management. Without being
constrained by a bus standard,
hardware and software can join in a
malleable design template. LBNL is
currently using this technique to
design a control system module for
ALS booster top off operation and
has completed designs for PEP-II
transverse feedback electronics and
ALS bunch cleaning. This
presentation will include a hands-on
demo of an FPGA evaluation board
running a simplified example of a
control system interface.
Emmanuel Mayssat
Lyncean Technologies, Inc.
On Fri, 2007-03-02 at 12:21 -0500, D. Peter Siddons wrote:
> Hi David,
>    FWIW, the RTEMS mailing list currently has a thread discussing an
> RTEMS BSP for the Xilinx Virtex 4. I don't know how close anyone is to
> submitting anything.
> Pete.
> David Kline wrote:
> > thanks for your response... at this point i don't have any specific
> > requirements/application
> > and only interested in finding out what has been done throughout the
> > community.
> > at the moment we use an epics brick (linux-based pc104 system) running
> > epics to communicate
> > with either an in-house designed external fgpa board (using the epics
> > brick dio) or over the bus
> > using the fpga104 from tri-m systems.
> > /david
> > Joze Dedic wrote:
> >> Hi David
> >> Can you give some more details for the requirements?
> >> Generally an OS is required to run EPICS, which requires the use of
> >> processor. Here you have several possibilities:
> >> - you can use soft-core processor for your FPGA circuit (for Altera that
> >> would be NIOS)
> >> - you can use in-FPGA hard-wired processor (Xilinx's Virtex II pro with
> >> Motorola Power PC)
> >> - use some standalone embedded processor and connect your FPGA circuit it
> >> via some bus that allows you enough data throughput
> >> One thing you should be aware of is that porting a Linux to a softcore or
> >> hard-wired in-FPGA processor is all but trivial (despite what the Xilinx and
> >> Altera state).
> >> Our practice is to use embedded platform for flexibility and connect it to
> >> the FPGA board over PC/104 bus.
> >> For example, we have built a 500MHz delay generator, capable of producing
> >> programmable delays with the jitter of less than 50ps, which is integrated
> >> in EPICS. For performance we used Xilinx FPGA (thus pushing the
> >> state-of-the-art FPGA to its edge) and for flexibility embedded platform
> >> running Linux (that was a piece of cake because we already have the range of
> >> solutions using embedded platforms).
> >> Cordially,
> >> Joze
> >> Joze Dedic, Ph.D.
> >> Senior Hardware Developer
> >> Cosylab d.o.o.
> >> Teslova ulica 30
> >> SI-1000 Ljubljana
> >> Slovenia
> >> Email: [email protected]
> >> Phone: +386 1 4776 759
> >> Mobile: +386 41 279 232
> >> http://www.cosylab.com
> >> http://www.microioc.com
> >>> -----Original Message-----
> >>> From: David Kline [mailto:[email protected]]
> >>> Sent: Friday, March 02, 2007 2:21 PM
> >>> To: [email protected]
> >>> Subject: epics / fpga
> >>> has anyone got epics to run on an altera fpga?
> >>> thanks in advance,
> >>> /david
> >>> David M. Kline                   [email protected]
> >>> Beamline Controls and Data Acquisition (BCDA) Argonne
> >>> National Laboratory, Advanced Photon Source
> >>> Argonne IL, 60439                      630.252.8639
> >>>                    Beamlines R Us
> > Argonne National Laboratory, Advanced Photon Source
> >                    Beamlines R Us
epics / fpga David Kline
RE: epics / fpga Joze Dedic
Re: epics / fpga David Kline
Re: epics / fpga D. Peter Siddons
Prev: EDM Related Displays Robert Emery
Next: Re: EDM Related Displays Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics / fpga D. Peter Siddons
Next: Re: epics / fpga Chris Timossi
