1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV aliases
To: Heinrich du Toit <[email protected]>
Cc: [email protected]
Date: Mon, 08 Oct 2007 10:49:39 -0500
Heinrich du Toit wrote:
Why not put the aliasing in a PV gateway?
This way you don't have to change the IOC's
And you don't have to change and client sofware.
You simply need to change the software on one gateway.
The disadvantage of using a gateway for aliasing is that you now have the relevant PV names listed in two places, so if you do eventually change the name of the original PV (because everyone is now using the alias) you have to remove it from the gateway configuration as well as change it in the IOC, and these changes have to be synchronized.
You might also want to avoid running large arrays or quickly changing signals through a PV gateway for performance reasons; there is no performance effect of doing aliasing on the IOC (other than to the PV name lookup process). Access Security could also be a problem through a PV gateway.
On Mon, 2007-10-08 at 10:01 -0400, Lawrence T. Hoff wrote:
	I may have been the one who initiated the
discussion a few years ago. I encountered a situation
which I believed was best addressed using server-side
aliases. I created a patch to EPICS core (which could
be loaded into a VxWorks system as a separate module),
which implemented server-side aliases.
See http://www.aps.anl.gov/epics/tech-talk/2003/msg00707.php for Larry's original posting, although I do not recommend using this code verbatim.
P.S. As near as I could tell, there was not universal
enthusiasm for server-side aliases at that time. Maybe
at next week's EPICS collaboration meeting the discussion
could begin anew?
PV Aliasing has been on my "To Do" list for Base for quite a while (my boss wants it too), prompted by your demonstration that it's not hard to do with the current data structures. The important question arises as to whether we need the ability to add aliases after iocInit() â I would guess not often, but I can see circumstances where it would be useful.
The only issues remaining that I can see would be a review of database locking (if we allow addition of aliases to a running IOC) and Access Security issues, and to decide how to specify the aliases to the IOC. I would prefer to extend the DB file syntax rather than use something like Larry's addPvAlias(name, alias) command, but adding alias support to dbLoadRecords() might preclude runtime aliasing.
I hope we'll be able to make some progress on implementing aliasing (amongst other things) at the EPICS Codeathon next April.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
RE: PV aliases Thompson, David H.
PV aliases Lecorche Eric
Re: PV aliases Lawrence T. Hoff
Re: PV aliases Heinrich du Toit
Prev: Re: PV aliases Heinrich du Toit
Next: RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: PV aliases Thompson, David H.
