1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PV aliases
To: [email protected]
Date: Tue, 09 Oct 2007 16:01:44 -0400
One  <possible> application for being able to add aliases after iocInit
might be an app where a bunch of calc records are banked in a soft IOC
ready to be used by just setting the INP fields, the CALC, field, and of
course the name (alias). Could be done on the fly.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Monday, October 08, 2007 11:50 AM
To: Heinrich du Toit
Cc: [email protected]
Subject: Re: PV aliases
Heinrich du Toit wrote:
> Why not put the aliasing in a PV gateway?
> This way you don't have to change the IOC's
> And you don't have to change and client sofware.
> You simply need to change the software on one gateway.
The disadvantage of using a gateway for aliasing is that you now have
the relevant PV names listed in two places, so if you do eventually
change the name of the original PV (because everyone is now using the
alias) you have to remove it from the gateway configuration as well as
change it in the IOC, and these changes have to be synchronized.
You might also want to avoid running large arrays or quickly changing
signals through a PV gateway for performance reasons; there is no
performance effect of doing aliasing on the IOC (other than to the PV
name lookup process).  Access Security could also be a problem through a
PV gateway.
> On Mon, 2007-10-08 at 10:01 -0400, Lawrence T. Hoff wrote:
>> 	I may have been the one who initiated the
>> discussion a few years ago. I encountered a situation
>> which I believed was best addressed using server-side
>> aliases. I created a patch to EPICS core (which could
>> be loaded into a VxWorks system as a separate module),
>> which implemented server-side aliases.
See http://www.aps.anl.gov/epics/tech-talk/2003/msg00707.php for Larry's
original posting, although I do not recommend using this code verbatim.
>> P.S. As near as I could tell, there was not universal
>> enthusiasm for server-side aliases at that time. Maybe
>> at next week's EPICS collaboration meeting the discussion
>> could begin anew?
PV Aliasing has been on my "To Do" list for Base for quite a while (my
boss wants it too), prompted by your demonstration that it's not hard to
do with the current data structures.  The important question arises as
to whether we need the ability to add aliases after iocInit() - I would
guess not often, but I can see circumstances where it would be useful.
The only issues remaining that I can see would be a review of database
locking (if we allow addition of aliases to a running IOC) and Access
Security issues, and to decide how to specify the aliases to the IOC.  I
would prefer to extend the DB file syntax rather than use something like
Larry's addPvAlias(name, alias) command, but adding alias support to
dbLoadRecords() might preclude runtime aliasing.
I hope we'll be able to make some progress on implementing aliasing
(amongst other things) at the EPICS Codeathon next April.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
RE: PV aliases Gurd, Pamela A.
PV aliases Lecorche Eric
Re: PV aliases Lawrence T. Hoff
Re: PV aliases Heinrich du Toit
Re: PV aliases Andrew Johnson
Prev: VME-GPIB replacement for GPIB-1014D Waggoner, Bill
Next: RE: PV aliases Gurd, Pamela A.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV aliases Andrew Johnson
