1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA wishlist :)
To: EPICS Techtalk <[email protected]>
Date: Wed, 12 Dec 2007 15:16:56 +0100
Hi Heinrich,
In (posix) C, there is a function that can do this: putenv(). Overwrite any environment variable you like in the initialization code of your application, before starting channel access.
I strongly agree in one point: This max array size thing is a pain. Especially for generic applications, such as the gateway, it is simply impossible to know the maximal array length in advance.
Dirk
Kay-Uwe Kasemir wrote:
On Dec 12, 2007, at 01:23 , Heinrich du Toit wrote:
Wouldn't it be nice to specify the EPICS_CA_* values firstly through functions in the library rather than environment variables only.
I agree, because environment variables can get set who knows where. It's often preferable to have settings of this kind in a per-application setup file, and for GUI programs one should be able to display and change settings via preference pages.
With Java clients, that's possible to some extend:
You can use
System.setProperty("gov.aps.jca.jni.JNIContext.addr_list", "..your address list..")
programmatically before(!) loading the JCA library,
or place these settings in Java property files.
(Example is for JNI. For CAJ, there are corresponding properties).
-Kay
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Re: CA wishlist :) Andrew Johnson
CA wishlist :) Heinrich du Toit
Re: CA wishlist :) Kay-Uwe Kasemir
Prev: vxworks driver 4 realtek 8139? marco_hair
Next: Re: CA wishlist :) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA wishlist :) Kay-Uwe Kasemir
