1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CA wishlist :)
To: Dirk Zimoch <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 12 Dec 2007 09:53:42 -0600
Dirk Zimoch wrote:
I strongly agree in one point: This max array size thing is a pain. Especially for generic applications, such as the gateway, it is simply impossible to know the maximal array length in advance.
Since the actual maximum array size that can be sent is the smallest of both the client and server's settings it's possible to set this to a giant number on your client workstations and gateways where you usually have the least idea what to set it to (our Unix shell configuration sets this at the same time as setting EPICS_HOST_ARCH). For each IOC you still have to work out how big your largest array field is and set the value appropriately, but at least this limits the scope of the problem.
I know Jeff has plans for removing this limit in the future, but it relies on completely replacing GDD with Data Access, which is a fairly major change.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
CA wishlist :) Heinrich du Toit
Re: CA wishlist :) Kay-Uwe Kasemir
Re: CA wishlist :) Dirk Zimoch
Prev: Re: CA wishlist :) Dirk Zimoch
Next: RE: CA wishlist :) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
