One of these specifies netbsd-x86 as the host architecture, the other specifies that this is also target platform.
John
-----Original Message-----
Sent: Tue 3/11/2008 9:59 AM
To: [email protected]
Subject: Re: Building MEDM
OK, found the problem
The file is supposed to be named 'CONFIG_SITE.<arch>.<arch>', and I had
it named 'CONFIG_SITE.<arch>'. A file named 'CONFIG_SITE.netbsd-x86'
doesn't match 'CONFIG_SITE.netbsd-x86.netbsd-x86'. Why is arch repeated
twice??? Is that for cross-compiling?
David
>>> "David Dudley" <[email protected]> 3/11/2008 9:45 AM >>>
Yes, I'm using the new "Extensions Top" config files.
I'm working with medm3_1_2_1. Please understand that this is part of
my project to port Epics to NetBSD, so I'm sure it's just something
that
is not being picked up by someone.
I'll capture a logfile of the compile, next time I compile the
package,
but the command I use is simply to move to the extensions directory,
and
type 'gmake' (NetBSD uses normal BSD 'make' as it's default make
program).
David
>>> "J. Lewis Muir" <[email protected]> 3/11/2008 9:17 AM >>>
On 3/11/08 9:35 AM, David Dudley wrote:
> Oh, so it's that file. I was looking for something in base. I have
> that file, and I have the settings set correctly in it. However,
when I
> get over to the build for MEDM, the variables appear to be blank.
This
> is only happening on MEDM, not on any of the other extensions.
> David
Hi, David.
What version of EPICS base are you using?
Are you using the new "Extensions Top" config files from
http://www.aps.anl.gov/epics/extensions/configure/index.php
What version of MEDM are you trying to compile?
Could you send the commands you're using to compile MEDM and their
output?
Lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
- Building MEDM David Dudley
- RE: Building MEDM Hammonds, John P.
- RE: Building MEDM David Dudley
- Re: Building MEDM J. Lewis Muir
- Re: Building MEDM David Dudley
Agilent E5810 GPIB Gateway issue Robert Emery
<2008>
<2008>
