Roger~thank you and Ralph very much!
在2008-10-15,"Owens, PH (Peter)" <[email protected]> 写道: >Not in that case. > >Some devices output binary numbers as strings of symbols >eg "!!!!.!.!" for 0xF5 >that can be parsed with the %B converter. > >dfanout would send the same data to all the records, >which is not what you want, but in any case >I would recommend Ralph Langes suggestions. > >Pete > >> -----Original Message----- >> From: [email protected] >> [mailto:[email protected]]On Behalf Of Silver >> Sent: 15 October 2008 15:54 >> To: tech-talk >> Subject: Re: RE: a question about mbbiDirect and fanout >> >> >> hi, Owens: >> >> Thank you very much~~~ your answer solved my much >> confusion. But about "Depending on the serial protocol you >> might be able to change the stream protocol file", can you >> give me more explaination? I use "%1r" toe match the 8bit >> value such as 0xfe, you means can do some calculation by some >> string operator like C++? >> ps, I checked the record manual, seems I can use both >> dfanout and seq record to implement your answer 3, am I right? >> >> ======= At 2008-10-15, 21:48:10 you wrote: ======= >> >> >Three possibilities: >> > >> >1. use a chain of FLNKs >> >2. use two fanout records. >> >3. use a seq record >> > >> >Why do you need the NOT value? >> >You could just assign ZNAM to ON rather than OFF in your bi record. >> >Depending on the serial protocol you might be able to change >> the stream protocol file. >> >In an case, I don't think a calc record has B0,B1,... >> fields, so you would need >> >a second mbbiDirect record. >> > >> >eg.: >> >record(mbbiDirect,"$(PREFIX):DISTATE") >> >{ >> > field(DTYP, "stream") >> > field(INP, "@power.proto mbbiDirect_distate_raw terminal") >> > field(SCAN, "1 second") >> > field(PINI, "YES") >> > field(FLNK, "$(PREFIX):DIOSTATE") >> > field(NOBT,8) >> >} >> > >> >record(bi,"$(PREFIX):DI0STATE") >> >{ >> > field(DESC, "MAIN RELAY") >> > field(INP, "$(PREFIX):DISTATE.B0") >> > field(ZSV, "NO_ALARM") >> > field(OSV, "MINOR") >> > field(ZNAM, "On") >> > field(ONAM, "Off") >> > field(FLNK, "$(PREFIX):DI1STATE") >> >} >> > >> > >> >> I want to get a raw value(8 bit) from hardware, after >> >> caculating the NOT value of it, 8 bi records will get the >> >> each bit value. For example, if I get the raw value "0xFE", >> >> caculate it with NOT operator to "0x01", then bi record 1th >> >> get the B0 bit, bi record 2th get the B1 bit...etc. >> >> If I set SCAN field to period of each bi record, maybe I >> >> can refresh the value. While is it possible only setting SCAN >> >> field of mbbiDirect record, then arosing all bi records being >> >> processed? >> >> I know if I use a fanout record(maybe dfanout record since >> >> fanout only support 6 values), I can do this. Is there any >> >> other possible way? >> >> ps, is there any other way to caculate the NOT value >> >> without using calc record? >> >> >> >> record(mbbiDirect,"$(PREFIX):DISTATE_RAW") >> >> { >> >> field(DTYP, "stream") >> >> field(INP, "@power.proto mbbiDirect_distate_raw terminal") >> >> field(SCAN, "Passive") >> >> field(PINI, "YES") >> >> field(FLNK, "$(PREFIX):DISTATE") >> >> field(NOBT,8) >> >> } >> >> >> >> record(calc,"$(PREFIX):DISTATE") >> >> { >> >> field(CALC, "~A") >> >> field(INPA, "$(PREFIX):DISTATE_RAW.VAL NPP") >> >> } >> >> >> >> record(bi,"$(PREFIX):DI0STATE") >> >> { >> >> field(DESC, "MAIN RELAY") >> >> field(SCAN, "1 second") >> >> field(INP, "$(PREFIX):DISTATE.B0 PP") >> >> field(ZSV, "MINOR") >> >> field(OSV, "NO_ALARM") >> >> field(ZNAM, "OFF") >> >> field(ONAM, "ON") >> >> } >> >> >> >> record(bi,"$(PREFIX):DI1STATE") >> >> { >> >> field(DESC, "CURRENT TRANSDUCER") >> >> field(SCAN, "1 second") >> >> field(INP, "$(PREFIX):DISTATE.B1 PP") >> >> field(OSV, "MAJOR") >> >> field(ZSV, "NO_ALARM") >> >> field(ONAM,"FAULT") >> >> field(ZNAM, "OK") >> >> } >> >> ....... >> >> >> >> Thank you very much for your help. >> >> >> >> >> >> Best regards >> >> Geyang 2008-10-15 >> >> >> >> >> >> >> > >> >> = = = = = = = = = = = = = = = = = = = = >> >> >> Best regards >> Geyang 2008-10-15 >> >> >> >> > [广告] 金秋最关注楼盘-房不胜房
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
