1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: nidaqmxbase synapps module
Date: Fri, 28 Nov 2008 17:08:43 +1100
Hi All.
I’m using  NIDAQmxBase written by Ulrik Pederson in 2007 in an Epics application driving a National Instruments card.
It all works, but if I open two ports to the card, one for DAC and the other for ADC, and I write fast enough to the DAC port, I get buffer underflows on the ADC port.
Has anyone found a fix for this? (It might be to do with the National Instruments drivers, of course, which are nidaqmxbase v 3.2.0 and NIKAL 1.7)
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
RE: nidaqmxbase synapps module Pedersen, UK (Ulrik)
Prev: Re: questions about stepper motor Pete Jemian
Next: RE: nidaqmxbase synapps module Pedersen, UK (Ulrik)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
