1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Access security problem
To: GOURNAY Jean-Francois <[email protected]>
Cc: [email protected]
Date: Thu, 10 Sep 2009 05:49:31 -0500
Actually Andrew is correct. Take the "A&2" as an example, when bit 1 is TRUE
then the result of the CALC is TRUE, when bit 1 is FALSE then the result of
the CALC will be FALSE. TRUE being = 1 and FALSE being = 0.
This may be why you are seeing this problem. If you log into the IOC console
and issue this command you will see the value that CA access security thinks
your CALC expression evaluates to as shown below.
asDumpRules
ASG(ID01ds_ACTION) {
        INPA(ID01ds:AccessSecurity) value=3.000000
        RULE(1,READ,NOTRAPWRITE)
        RULE(0,WRITE,TRAPWRITE) {
                UAG(operator)
                HAG(local)
                CALC("A<3") result=FALSE
                UAG(flcord)
                HAG(flctrl,local)
                CALC("A<2") result=FALSE
        RULE(1,WRITE,TRAPWRITE) {
                UAG(sec01)
                HAG(sec01)
                CALC("A<1") result=FALSE
                UAG(appdev)
Marty
GOURNAY Jean-Francois wrote:
Dear Andrew,
I think you are wrong. Remember that the CALC expression must return TRUE or FALSE which will not be the case with A&2, A&4 ...
I guess my scheme is correct. Everything works except this problem with this spiral2mgr user that I don't understand (see the table below from my previous mail). We will try to overcome it in a way or another ... unless somebody has another idea about it !!!
J.F. Gournay
CEA Saclay
IRFU/SIS
-----Message d'origine-----
De : Andrew Johnson [mailto:[email protected]] Envoyé : mercredi 9 septembre 2009 16:56
À : [email protected]
Cc : GOURNAY Jean-Francois
Objet : Re: Access security problem
On Wednesday 09 September 2009 07:34:52 GOURNAY Jean-Francois wrote:
I did more systematic tests and I have this strange situation:
ASGVAL  UAG      spiral2  spiral2mgr      gournay
1       tous      W        W               W        OK
2       develop   -        - (should be W) -        WRONG
4       physique  W        -               -        OK
8       gournay   -        W (should be -) W        WRONG
W : database WRITE access
- :  no write access
I modified the CALC expressions accordingly to Martin suggestion :
CALC("A&1") instead of CALC("A&1=1").  But I don't think I have to write
CALC (A>0&&A<2) as my A value comes from a longout record.
You're right there, but for historical reasons the relative precedence of the ">>" and "=" operators are different in C and CALC, so you do need to change your expressions:
            CALC("A&1=1")
As Marty suggested "A&1" is sufficient here
            CALC("A>>1=1")
CALC actually evaluates this as "A>>(1=1)" which is not what you mean. You could use "(A>>1)=1" but I would suggest "A&2" here instead.
            CALC("A>>2=1")
"A&4"
            CALC("A>>3=1")
"A&8"
Using fewer operators will also parse and execute faster.
This message sent yesterday didn't show up.
That's because you actually sent it to tech-talk-bounces@aps., not to tech-talk@aps., and I didn't get a chance to forward it manually before you re-sent it.
HTH,
- Andrew
TR: Access security problem GOURNAY Jean-Francois
RE: Access security problem GOURNAY Jean-Francois
Re: Access security problem Andrew Johnson
Prev: RE: Access security problem GOURNAY Jean-Francois
Next: Killing a soft IOC which doesn't have an interactive shell Rees, Nick (DLSLtd,RAL,DIA)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: 2eSST??? Eric Bjorklund
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
