1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Python client application survey
To: EPICS Tech Talk <[email protected]>
Date: Thu, 1 Oct 2009 15:01:02 +0100 (BST)
On Thu, 1 Oct 2009, Michael Abbott wrote:
> On Wed, 30 Sep 2009, Andrew Johnson wrote:
> > I would encourage those working on this to read the release notes for
> > R3.14.11 as there are a couple of things we added which you guys are
> > going to want to provide support for:
> >  * Long strings.  Important for accessing DBF_xxLINK fields since record
> > names can be up to 60 characters long, so you can't always read or
> > change the value of a link field using a 40 character DBF_STRING.
So implementing this for caget/camonitor seems to be easy, the following
patch against cothread 1-14 seems to do the trick.  If anyone with a .11
server to hand fancies giving a go I'd be grateful;  it seems to work ok
for me.
--- cothread/dbr.py     (revision 36209)
+++ cothread/dbr.py     (working copy)
@@ -595,7 +595,10 @@
     dbr_type = DbrCodeToType[datatype]
     raw_dbr = ctypes.cast(raw_dbr, ctypes.POINTER(dbr_type))[0]
-    if count == 1:
+    if name[-1] =='$'  and  raw_dbr.dtype is numpy.uint8:
+        # Special case hack for long strings returned as DBR_CHAR arrays.
+        result = ca_str(ctypes.string_at(raw_dbr.raw_value))
+    elif count == 1:
         # Single scalar values can be created directly from the raw value
         result = raw_dbr.raw_value[0]
         if dbr_type.dtype is str_dtype:
> 6. Does this also work in the same way for caput?  I'm guessing so.
This one is a bit nastier because in cothread.catools the DBR_ coding for
caput is entirely determined by the Python data type, so I normally never
look at the field type ... and it looks like converting a string into a
numpy array is a lot clunkier than I'd like.  But this patch should apply
against 1-14; I'll clean it up and restructure a little for 1-15.
--- cothread/catools.py (revision 36223)
+++ cothread/catools.py (working copy)
@@ -49,6 +49,7 @@
 import sys
 import atexit
 import traceback
+import numpy
 import cothread
 from cadef import *
@@ -686,7 +687,13 @@
     channel.Wait(timeout)
     # Assemble the data in the appropriate format.
+    if pv[-1] == '$' and isinstance(value, str) and \
+            ca_field_type(channel) == DBR_CHAR:
+        # Tricky hack for long strings on 3.14.11 and above servers: send
+        # strings to PVs ending in $ as char arrays.
+        value = numpy.array(map(ord, value + '\0'), dtype = numpy.uint8)
     datatype, count, dbr_array = value_to_dbr(value)
     if wait:
         # Assemble the callback context and give it an extra reference count
         # to keep it alive until the callback handler sees it.
As a first stab, it seems to work just fine against a .11-pre server.
Disappointed to answer one of my earlier questions: have to request
PV_NAME.VAL$, as PV_NAME$ doesn't work, however I'm sure that's not very
important.
Regarding my null termination question, the answer seems to be that
strings *are* null terminated; this probably needs to be explicitly stated
somewhere!
Re: EPICS Python client application survey Matt Newville
Re: EPICS Python client application survey Benjamin Franksen
Re: EPICS Python client application survey Andrew Johnson
Re: EPICS Python client application survey Michael Abbott
Prev: Re: EPICS Python client application survey Benjamin Franksen
Next: Re: EPICS Python client application survey Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
