Let's hear it for the IT people!
A solution is found via a "click-through" parameter which may or may not
already be present in a .plist file.
For Leopard (with X11 at version 2.1.5) look for the parameter
"wm_click_through" in the file ~/Library/Preferences/org.x.X11.plist.
Change the value from False to True.
If that parameter is not present within the plist (it wasn't for me),
execute the following command from an xterm:
"defaults write org.x.X11 wm_click_through -bool true"
Either way, start from a new X11 session (kill the server and restart).
MEDM now functions as expected.
For more info (and for pre-Leopard solution) see:
http://web.ipac.caltech.edu/staff/hoard/mactips/MacOSX_configuration_tips.html#click_x11
My thanks again to Jon and Dave, our lonely Mac support crew.
Noboru Yamamoto wrote:
> Hi, All:
> I also used to have same problem and used same method descirbed by Eric,
> right click on display to create componets.
> Now, I don't have the problem anymore. I don't remember when this
> problem went away, but my current environment:
> MacOSX 10.6.2
> X11 2.3.4
> openMotif 2.2.3
> EPICS base 3.14.11
> medm 3.1.4
> does not have the problem reported.
> Regards,
> Noboru Yamamoto
> J-PARC control group
> JAPAN
> (10/01/07 10:57), David Dudley wrote:
>> Is this problem under Leopard, or Snow Leopard?
>> I've had the same problem with both EDM and MEDM ever since I updated up to
>> Snow Leopard.
>> I finally tracked the problem down (at least on my system...) to OpenMotif
>> 2.32.
>> Backing down to OpenMotif 2.30 corrected the problem for me. Upgrading back
>> to 2.32 and rebuilding caused the problem to return.
>> David Dudley
>> On 1/6/10 4:52 PM, "Eric Norum"<[email protected]> wrote:
>>> The XKEYSYMDB change didn't work for me. Josh?
>>> I suspect that this problem lies elsewhere, since the controls seem to work
>>> other places in MEDM. One possible thing to look at is that the widgets in
>>> question in the palette window seem to have 'tool tips' associated with them.
>>> Whenever I mouse over one of the widgets I get a pop-up describing the widget.
>>> Perhaps it is this operation that is somehow getting in the way of the mouse
>>> click getting through to the widget?
>>> On Jan 6, 2010, at 12:27 PM, Matt Newville wrote:
>>>> Josh,
>>>> It sounds like it's probably a problem with XKeysymDB. A fix may be
>>>> as simple as
>>>> export XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB. (or whereever XkeysymDB
>>>> is)
>>>> --Matt
>>>> On Wed, Jan 6, 2010 at 2:12 PM, Mark Rivers<[email protected]> wrote:
>>>>> OK, so the problem is with the X server, not the client, since that
>>>>> behaviour does not occur when displaying MEDM from the other platform on
>>>>> Linux or Windows, right? Do you know when the problem started? I am
>>>>> not a Mac user, but Lewis Muir and Eric Norum are, so maybe they have
>>>>> some ideas?
>>>>> -----Original Message-----
>>>>> From: Josh Stein [mailto:[email protected]]
>>>>> Sent: Wednesday, January 06, 2010 2:10 PM
>>>>> To: Mark Rivers
>>>>> Cc: EPICS tech-talk
>>>>> Subject: Re: Odd MEDM behavior on OS-X
>>>>> Good question Mark, and I should have pointed this out before...
>>>>> Running MEDM on other platforms while exporting the display back to my
>>>>> Mac produces identical results (e.g. those specific buttons are still
>>>>> non-functional).
>>>>> Mark Rivers wrote:
>>>>>> Can you isolate the problem to the X server or client? What happens
>>>>> if
>>>>>> you run the same version of medm on a Linux system and display on your
>>>>>> Mac, or run medm on your Mac and display on Linux or Windows?
>>>>>> Mark
>>>>>> From: [email protected]
>>>>>> [mailto:[email protected]] On Behalf Of Josh Stein
>>>>>> Sent: Wednesday, January 06, 2010 2:02 PM
>>>>>> To: EPICS tech-talk
>>>>>> Subject: Odd MEDM behavior on OS-X
>>>>>> Ok, we're having an odd problem here at APS which has myself and
>>>>> others
>>>>>> scratching our heads.
>>>>>> When running MEDM on my Mac (OS X - Leopard) I am able to open and
>>>>>> execute existing screens, but when I try to add an object (using the
>>>>>> object pallet) things get bizarre. I am unable to successfully
>>>>> interact
>>>>>> with any of the object buttons within the palette (so, for example, if
>>>>> I
>>>>>> wanted to place a static rectangle using the drawing object, I cannot
>>>>>> seem to get that button to "press"). All buttons within the object
>>>>>> palette are similarly crippled.
>>>>>> Other uses of the mouse button within MEDM seem fine - for example
>>>>> when
>>>>>> a screen is operating and connected to PVs, I can click on related
>>>>>> displays, or other controllers and have them function properly.
>>>>>> Furthermore the other two palette types (Resource and Color) function
>>>>>> fine.
>>>>>> I realize I can place objects by right-clicking on the display - but
>>>>>> something has changed recently, as I've traditionally always used the
>>>>>> object palette.
>>>>>> Any ideas? Our Mac people have tried differing versions of the OS with
>>>>>> no difference noted.
>>>>>> --Josh
- Re: Odd MEDM behavior on OS-X David Dudley
- Re: Odd MEDM behavior on OS-X Noboru Yamamoto
Re: mbboDirect problem Dirk Zimoch
streamDevice and I/O Intr processing Jens . Eden
<2010>
<2010>
