1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Cross compiling EPICS for cris v10
To: "Florian Feldbauer" <[email protected]>
Cc: tech-talk Mailing List <[email protected]>
Date: Fri, 1 Oct 2010 08:01:24 -0500
The CRIS is a small embedded IOC right?  It sounds like maybe your linkage table is exceeding some maximum or default size?  Are there compiler options to increase the size of the table?
Sent: Fri 10/1/2010 7:53 AM
To: Mark Rivers
Cc: Florian Feldbauer; Dirk Zimoch; Burkhard Kolb; tech-talk Mailing List
On Fri, 1 Oct 2010, Mark Rivers wrote:
> OK, so you can build executables.  Using makeBaseAppl.pl can you build the "example" application?  That would show whether you can build a simple IOC.  It would establish if the problem arises from something specific to your IOC, or whether IOCs cannot be built at all for linux-cris_v10.
I've just tested to build the example application using makeBaseApp.pl
without changing any files. This works.
But as soon as I add Asyn and Stream I get the error.
> Mark
> ________________________________
> From: Florian Feldbauer [mailto:[email protected]]
> Sent: Fri 10/1/2010 7:14 AM
> To: Mark Rivers
> Cc: Dirk Zimoch; Burkhard Kolb; tech-talk Mailing List; Florian Feldbauer
> Hi Mark,
> the executables in base and asyn are all sucessfully built.
> I've used makeBaseApp.pl to create the Makefiles and other stuff for
> building my IOC application. This two seems to work.
> The application builts for linux-x86 target. Only for linux-cris_v10
> I get the error.
> Florian
>> Florian,
>> Can you confirm that you successfully built some executables, like the ones in base (caput, caget) and the ones in asyn (testAsynPortDriver). Look in the bin/linux-x86 directories there.  If so, then we need to figure out why it is failing to build your IOC appplication, which it built other programs OK.  Is it just the size of the resulting program or something else?
>> What happens if you use makeBaseApp.pl to build the example IOC applicaton?  Does that build OK?
>> Mark
>> From: Dirk Zimoch [mailto:[email protected]]
>> Sent: Fri 10/1/2010 7:01 AM
>> To: Burkhard Kolb
>> Cc: Mark Rivers; tech-talk Mailing List; Florian Feldbauer
>> Subject: Re: Cross compiling EPICS for cris v10
>> PLT seens to mean "procedure linkage table". The compiler source code is
>> here:
>> https://www.calcforge.org/trac/emu-tigcc/browser/tiemu/trunk/src/core/gdb/bfd/elf32-cris.c?rev=1818
>> Of course, that does not mean that I have any clue what caused the error.
>> Dirk
>> Burkhard Kolb wrote:
>>> Well Mark,
>>> Peter Zumbruch posted the same error some time ago on 28th of June (subject: No PLT for relocation)
>>> At that time nobody responded ...
>>> We also still have no solution, it seems to be a linker problem with the cris-gnu stuff.
>>> Burkhard
>>> Am 30.09.2010 um 18:04 schrieb Mark Rivers:
>>>> I have never seen an error like that.
>>>> What type of system are you building for, an embedded IOC or a
>>>> workstation?
>>>> You are using asyn R4-10 which is quite old, and was tested with EPICS
>>>> 3.14.8, but I don't think that is the problem.  Could you be running out
>>>> of memory on the target system?
>>>> It did build the executables in the asyn test directories OK, right?  So
>>>> the linker can build executables, just not your IOC executable?
>>>> Mark
>>>> -----Original Message-----
>>>> Sent: Thursday, September 30, 2010 10:29 AM
>>>> To: Mark Rivers
>>>> Cc: Florian Feldbauer; [email protected]
>>>> Ok, now I was able to build synApps (Stream, Asyn, Calc, and sscan). But
>>>> still I can't build my IOC application
>>>> /usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
>>>> xis-linux-gnu/bin/ld:
>>>> /usr/Epics/synApps/synApps_5_4_1/support/asyn/4-10/lib/linux-cris_v10/li
>>>> basyn.a(devAsynInt32.o):
>>>> No PLT for relocation R_CRIS_32_GOTPLT against symbol
>>>> `epicsRingBytesCreate' from .text section
>>>> final link failed: Bad value
>>>> collect2: ld returned 1 exit status
>>>> make[3]: *** [slowCtrl] Error 1
>>>> make[3]: Leaving directory
>>>> `/usr/Epics/slowCtrl/slowCtrlApp/src/O.linux-cris_v10'
>>>> make[2]: *** [install.linux-cris_v10] Error 2
>>>> make[2]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp/src'
>>>> make[1]: *** [src.install] Error 2
>>>> make[1]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp'
>>>> make: *** [slowCtrlApp.install] Error 2
>>>> Florian
>>> Dr. Burkhard Kolb
>>> Pleikartsförster Str. 38
>>> 69124 Heidelberg
>>> Germany
>>> E-Mail: [email protected]
>>> Tel: +49 6221 718640 / Fax: +49 6221 718641
> | Florian Feldbauer                 |
> | Ph.D. student                     |
> | Institut für Experimentalphysik I |
> | Ruhr-Universität Bochum           |
> | Universitätsstr. 150              |
> | D-44780 Bochum                    |
> | Office: NB 2/173                  |
> | Phone:  (+49)234 / 32-23538       |
> | Fax:    (+49)234 / 32-14170       |
> | Web:    http://www.ep1.rub.de <http://www.ep1.rub.de/>  <http://www.ep1.rub.de/>      |
| Florian Feldbauer                 |
| Ph.D. student                     |
| D-44780 Bochum                    |
| Office: NB 2/173                  |
| Web:    http://www.ep1.rub.de <http://www.ep1.rub.de/>      |
Cross compiling EPICS for cris v10 Florian Feldbauer
RE: Cross compiling EPICS for cris v10 Mark Rivers
RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Re: Cross compiling EPICS for cris v10 Burkhard Kolb
Re: Cross compiling EPICS for cris v10 Dirk Zimoch
Prev: RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Next: RE: Cross compiling EPICS for cris v10 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 01 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
