HI Tech-talk,I am trying to build an IOC to communicate with serial devices through the serial to Ethernet Device Server.
The serial device supports the streams of hex format.
The binary command format when using RS232 or RS485 is as follows: Bytes Meaning 1 Module address 1 Command number 1 Type number 1 Motor or Bank number 4 Value (MSB first!)
1 Checksum total: 9 bytes
the checksum is calculated by adding up all bytes (including the module address byte) using 8-bit addition. Here is the examples to show how to do this: in C: unsigned char i, Checksum; unsigned char Command[9];
//Set the “Command” array to the desired command Checksum = Command[0]; for(i=1; i<8; i++) Checksum+=Command[i]; Command[8]=Checksum; //insert checksum as last byte of the command
//Now, send it to the module
I want to control the motor to rotate right through the serial device.
Instruction: Rotate right, motor #1, velocity = 350 Binary: Byte Index 0 1 2 3 4 5 6 7 8
Function Target- Instruction Type Motor/ Operand Operand Operand Operand Checksum address Number Bank Byte3 Byte2 Byte1 Byte0
Value (hex) 0x01 0x01 0x00 0x01 0x00 0x00 0x01 0x5e 0x62
By writing streamDevice protocol file(out'\x01\x01\x00\x01\x00\x00\x01\x5e\x62';),motor will rotate. Using "EDM" or "caput" to
input the variable,where do I do my processing (like calculating the Checksum and convert the velocity to four bytes long)? where
write my own parsing code in C?having other approaches. Could you give any example?
Yahto Dam 2010.11.16
- RE: the hex instruction convert Mark Rivers
- RE: the hex instruction convert peter.owens
Re: Last chance to save the sequencer's pv layer Maren Purves
Re: asyn driver on Windows XP Dirk Zimoch
<2010>
2025
EPICS Base R3.14.12-rc1 now available Andrew Johnson
<2010>
2025
