1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: EDM segmentation fault in colorInfoClass
Date: Thu, 16 Feb 2012 10:54:45 -0800
Hello,
I am trying to debug/fix an issue in EDM and hence trying to build it from scratch on a Redhat 6.1 64 bit machine. I have downloaded edm-1-12-71.tgz and am able to build it successfully. However, I get a core dump when I try to add a widget/line etc. Here’s the stack trace; all of these issues seem to come from an invalid/null colorInfoClass instance passed on from the activeLineClass::createInteractive method to the widgets. It is possible I have a configuration issue; I have followed the instructions as outlined at http://ics-web.sns.ornl.gov/edm/docs/retrieveDocument.php?documentId=19&folderId=1 . I have tried this with openMotif-2.2.3 (in addition to openmotif-2.3.3-4  which is the version that ships with this linux).
Any pointers are much appreciated.
Murali
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7934997 in colorInfoClass::getPixelByIndex (this=0x31656c69, index=0) at ../color_pkg.cc:6344
6344         if ( index >= max_colors+num_blinking_colors )
Missing separate debuginfos, use: debuginfo-install giflib-4.1.6-3.1.el6.x86_64 glibc-2.12-1.47.el6_2.5.x86_64 libICE-1.0.6-1.el6.x86_64 libSM-1.1.0-7.1.el6.x86_64 libX11-1.3-2.el6.x86_64 libXau-1.0.5-1.el6.x86_64 libXcursor-1.1.10-2.el6.x86_64 libXext-1.1-3.el6.x86_64 libXfixes-4.0.4-1.el6.x86_64 libXi-1.3-3.el6.x86_64 libXmu-1.0.5-1.el6.x86_64 libXp-1.0.0-15.1.el6.x86_64 libXrender-0.9.5-1.el6.x86_64 libXt-1.0.7-1.el6.x86_64 libXtst-1.0.99.2-3.el6.x86_64 libgcc-4.4.6-3.el6.x86_64 libpng-1.2.46-1.el6_1.x86_64 libstdc++-4.4.6-3.el6.x86_64 libuuid-2.17.2-12.4.el6.x86_64 libxcb-1.5-1.el6.x86_64 zlib-1.2.3-27.el6.x86_64
(gdb) bt
#0  0x00007ffff7934997 in colorInfoClass::getPixelByIndex (this=0x31656c69, index=0) at ../color_pkg.cc:6344
#1  0x00007ffff7ccb1dc in colorInfoClass::pix (this=0x31656c69, index=0) at ../../../../include/edm/color_pkg.h:219
#2  0x00007ffff794b7a0 in pvColorClass::changeIndex (this=0x74d918, color=0, ci=0x31656c69) at ../pvColor.cc:405
#3  0x00007ffff794b956 in pvColorClass::setColorIndex (this=0x74d918, color=0, ci=0x31656c69) at ../pvColor.cc:474
#4  0x00007ffff7c63120 in activeLineClass::createInteractive (this=0x74d570, aw_obj=0x704cc0, _x=108, _y=188, _w=176, _h=232) at ../line_obj.cc:587
#5  0x00007ffff78e112a in createPopup_cb (w=0x710a60, client=0x704cc0, call=0x7fffffffc520) at ../act_win.cc:7674
#6  0x00000039cd81393f in XtCallCallbackList () from /usr/lib64/libXt.so.6
#7  0x00007ffff72902e2 in BtnUp (wid=0x710a60, event=0x7fffffffcb90, params=<value optimized out>, num_params=<value optimized out>) at PushB.c:2656
#8  0x00000039cd84a76d in ?? () from /usr/lib64/libXt.so.6
#9  0x00000039cd84a8c8 in ?? () from /usr/lib64/libXt.so.6
#10 0x00000039cd84b224 in _XtTranslateEvent () from /usr/lib64/libXt.so.6
#11 0x00000039cd821b8b in XtDispatchEventToWidget () from /usr/lib64/libXt.so.6
#12 0x00000039cd8223bb in ?? () from /usr/lib64/libXt.so.6
#13 0x00000039cd821344 in XtDispatchEvent () from /usr/lib64/libXt.so.6
#14 0x00000039cd82eae9 in XtAppProcessEvent () from /usr/lib64/libXt.so.6
#15 0x00007ffff793a2de in genericProcessAllEvents (sync=0, app=0x647eb0, d=0x6491e0) at ../utility.cc:1186
#16 0x00007ffff793a384 in processAllEvents (app=0x647eb0, d=0x6491e0) at ../utility.cc:1216
#17 0x00007ffff78cb5ca in appContextClass::applicationLoop (this=0x631d10) at ../app_pkg.cc:6174
#18 0x0000000000408e15 in main (argc=1, argv=0x7fffffffda88) at ../main.cc:2725
(gdb) inspect this->change
Cannot access memory at address 0x31656e21
Prev: Re: registerRecordDeviceDriver fails at registryRecordTypeFind Andrew Johnson
Next: New Tornado 2.2.x compilers for Linux-x86 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Precise time beyond 2038 Di Maio Franck
Next: RE: EDM segmentation fault in colorInfoClass Shankar, Murali
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
