Subject: put callback queuing
To: EPICS <[email protected]>
Date: Thu, 21 Jun 2012 10:50:40 -0400
Recently at BNL, we've been investigating a report of unexpected
behavior found when using put-callbacks to a Motor Record (verified
using a simulated motor). After initiating a long-running motion with
caput -c -w 100 test:motor1 <some large value>
trying to stop the motor in the following way fails:
caput -c -w 100 test:motor1.STOP 1
After observing that the 2nd put-with-callback to stop the motion is
not seen by the Motor Record, a look through
$EPICS_BASE/src/rsrv/camessage.c reveals that concurrent put notifies
are queued in the IOC server:
if ( pciu->pPutNotify ) {
         * serialize concurrent put notifies
I can understand serializing put-callbacks on a per-channel basis, but
the implementation appears to serialize _per-record_.
What am I missing? A little help please...
-- dc
Re: put callback queuing Andrew Johnson
Re: put callback queuing Tim Mooney
Prev: Is it possible to create a cross-compile environment using cygwin and vxWorks on Windows XP 송영기
Next: Re: put callback queuing Andrew Johnson
Prev: Re: Is it possible to create a cross-compile environment using cygwin and vxWorks on Windows XP Andrew Johnson
