Subject: Re: EPICS Base version 3.15.0.1 released
To: Anze Zagar <[email protected]>
Cc: [email protected]
Date: Mon, 13 Aug 2012 12:32:47 -0500
I have successfully built the released version of synApps_5_6 against
base 3.15.0.1 on RHEL6 (linux-x86_64-debug).  The details of my changes
are attached.  Not all of my changes are backwards-compatible.
I had to modify the following files:
asyn-4-18/asyn/asynRecord/asynRecord.dbd
asyn-4-18/asyn/devGpib/devCommonGpib.c
asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd
asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd
asyn-4-18/asyn/gsIP488/drvGsIP488.dbd
asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd
asyn-4-18/asyn/ni1014/drvNi1014.dbd
asyn-4-18/asyn/vxi11/drvVxi11.dbd
autosave-4-8/asApp/src/fGetDateStr.c
autosave-4-8/asApp/src/save_restore.c
calc-2-9/calcApp/src/aCalcoutRecord.c
ipac-2-11/tyGSOctal/tyGSOctal.dbd
mca-7-1/mcaApp/mcaSrc/mcaRecord.c
motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd
motor-6-7/motorApp/MotorSrc/motorRecord.cc
motor-6-7/motorApp/MotorSrc/motorRecord.dbd
motor-6-7/motorApp/OrielSrc/devEMC18011.cc
motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc
motor-6-7/motorApp/PiSrc/devPIE516.cc
motor-6-7/motorApp/PiSrc/devPIE710.cc
motor-6-7/motorApp/PiSrc/devPIE816.cc
motor-6-7/motorApp/SoftMotorSrc/devSoft.cc
motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc
seq-2-1-3/configure/RULES_BUILD
sscan-2-7/sscanApp/src/Makefile
sscan-2-7/sscanApp/src/menuSscan.dbd
sscan-2-7/sscanApp/src/recDynLink.c
sscan-2-7/sscanApp/src/recDynLink.h
sscan-2-7/sscanApp/src/saveData.c
sscan-2-7/sscanApp/src/scanparmRecord.dbd
sscan-2-7/sscanApp/src/sscanMenu.dbd
sscan-2-7/sscanApp/src/sscanRecord.c
sscan-2-7/sscanApp/src/sscanRecord.dbd
sscan-2-7/sscanApp/src/sscanSupport.dbd
std-3-1/stdApp/src/devTimeOfDay.c
stream-2-5-1/streamDevice/src/AsynDriverInterface.cc
stream-2-5-1/streamDevice/src/Makefile
stream-2-5-1/streamDevice/src/StreamEpics.cc
stream-2-5-1/streamDevice/srcSynApps/Makefile
stream-2-5-1/streamDevice/streamApp/Makefile
vac-1-4/vacApp/src/devDigitelPump.dbd
vac-1-4/vacApp/src/devVacSen.dbd
xxx-5-6/xxxApp/src/Makefile
xxx-5-6/xxxApp/src/xxxCommonInclude.dbd
Kevin
diff --git a/.gitignore b/.gitignore
index 501c31c..def9913 100644
--- a/.gitignore
+++ b/.gitignore
@@ -9,6 +9,7 @@ html
 O.Common
 O.linux-x86_64
 O.linux-x86_64-debug
+O.solaris-sparc-gnu
 envPaths
 cdCommands
 bnf.inc
diff --git a/asyn-4-18/asyn/asynRecord/asynRecord.dbd b/asyn-4-18/asyn/asynRecord/asynRecord.dbd
index e39dd9e..4fb93ed 100644
--- a/asyn-4-18/asyn/asynRecord/asynRecord.dbd
+++ b/asyn-4-18/asyn/asynRecord/asynRecord.dbd
@@ -122,7 +122,6 @@ recordtype(asyn) {
         promptgroup(GUI_INPUTS)
         special(SPC_MOD)
         interest(1)
-        initial("")
         size(40)
     field(ADDR,DBF_LONG) {
@@ -143,7 +142,6 @@ recordtype(asyn) {
         special(SPC_MOD)
         interest(2)
-        initial("")
         size(40)
     field(REASON,DBF_LONG) {
diff --git a/asyn-4-18/asyn/devGpib/devCommonGpib.c b/asyn-4-18/asyn/devGpib/devCommonGpib.c
index ad7e19a..b28ac15 100644
--- a/asyn-4-18/asyn/devGpib/devCommonGpib.c
+++ b/asyn-4-18/asyn/devGpib/devCommonGpib.c
@@ -21,6 +21,7 @@
 #include <epicsAssert.h>
 #include <epicsStdio.h>
+#include <epicsVersion.h>
 #include <recGbl.h>
 #include <dbAccess.h>
 #include <dbScan.h>
@@ -449,7 +450,6 @@ long  devGpib_readEv(eventRecord * pev)
 static void evFinish(gpibDpvt * pgpibDpvt,int failure)
-    unsigned short value;
     eventRecord *pev = ((eventRecord *) (pgpibDpvt->precord));
     gpibCmd *pgpibCmd = gpibCmdGet(pgpibDpvt);
     int cnvrtStat;
@@ -470,9 +470,14 @@ static void evFinish(gpibDpvt * pgpibDpvt,int failure)
             "%s no msg buffer\n",pev->name);
         failure = -1;
     } else {/* interpret msg with predefined format and write into val/rval */
+#if ((EPICS_VERSION<=(3)) && (EPICS_REVISION<=(14)))
+        unsigned short value;
         char *format = (pgpibCmd->format) ? (pgpibCmd->format) : "hu";
         if (sscanf(pgpibDpvt->msg, format, &value) == 1) {
             pev->val = value;
+#else
+        if (sscanf(pgpibDpvt->msg, " %39s", pev->val) == 1) {
+#endif
             pev->udf = FALSE;
         } else { /* sscanf did not find or assign the parameter */
             failure = -1;
diff --git a/asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd b/asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd
index 08d0245..e98c2c9 100644
--- a/asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd
+++ b/asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd
@@ -1,3 +1,2 @@
 registrar(drvAsynIPPortRegisterCommands)
 registrar(drvAsynIPServerPortRegisterCommands)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd b/asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd
index a6ebb6a..3379453 100644
--- a/asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd
+++ b/asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd
@@ -1,2 +1 @@
 registrar(drvAsynSerialPortRegisterCommands)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/gsIP488/drvGsIP488.dbd b/asyn-4-18/asyn/gsIP488/drvGsIP488.dbd
index 443813e..1f045ac 100644
--- a/asyn-4-18/asyn/gsIP488/drvGsIP488.dbd
+++ b/asyn-4-18/asyn/gsIP488/drvGsIP488.dbd
@@ -1,3 +1,2 @@
 registrar(gsIP488RegisterCommands)
 variable(gsip488Debug,int)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd b/asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd
index 161600c..db40027 100644
--- a/asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd
+++ b/asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd
@@ -1,2 +1 @@
 registrar(GpibBoardDriverRegister)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/ni1014/drvNi1014.dbd b/asyn-4-18/asyn/ni1014/drvNi1014.dbd
index 792b314..1843372 100644
--- a/asyn-4-18/asyn/ni1014/drvNi1014.dbd
+++ b/asyn-4-18/asyn/ni1014/drvNi1014.dbd
@@ -1,2 +1 @@
 registrar(ni1014RegisterCommands)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/vxi11/drvVxi11.dbd b/asyn-4-18/asyn/vxi11/drvVxi11.dbd
index 4a78b14..a73fb27 100644
--- a/asyn-4-18/asyn/vxi11/drvVxi11.dbd
+++ b/asyn-4-18/asyn/vxi11/drvVxi11.dbd
@@ -1,2 +1 @@
 registrar(vxi11RegisterCommands)
-include "asyn.dbd"
diff --git a/autosave-4-8/asApp/src/fGetDateStr.c b/autosave-4-8/asApp/src/fGetDateStr.c
index 147fc80..a5b0c51 100644
--- a/autosave-4-8/asApp/src/fGetDateStr.c
+++ b/autosave-4-8/asApp/src/fGetDateStr.c
@@ -67,19 +67,19 @@ DEVELOPMENT CENTER AT ARGONNE NATIONAL LABORATORY (708-252-2000).
 #include <dbCommon.h>
 #include <recGbl.h>
 #include <devSup.h>
-#include <tsDefs.h>
 #include <fGetDateStr.h>
 int	fGetDateStr( char datetime[])
-	TS_STAMP   now;
+	epicsTimeStamp   now;
 	char	   time_text[32];
 	char	   tmp[16];
 	char	*p, *p1, *p2;
-	tsLocalTime(&now);
-	p = tsStampToText( &now, TS_TEXT_MMDDYY, time_text);
+	epicsTimeGetCurrent(&now);
+	/*p = tsStampToText( &now, TS_TEXT_MMDDYY, time_text);*/
+	p = epicsTimeToStrftime(time_text, sizeof(time_text), "%m/%d/%y %H:%M:%S.%09f", &now);
 	p2 = tmp;
 	if((p1 = strchr(p, (int) '/'))) {
 		*p1= 0;
diff --git a/autosave-4-8/asApp/src/save_restore.c b/autosave-4-8/asApp/src/save_restore.c
index d7aaa11..9a4770b 100644
--- a/autosave-4-8/asApp/src/save_restore.c
+++ b/autosave-4-8/asApp/src/save_restore.c
@@ -148,7 +148,6 @@
 #include	<epicsThread.h>
 #include	<epicsExport.h>
 #include	<iocsh.h>
 #include    <macLib.h>
 #include	<callback.h>
 #include	<epicsMutex.h>
diff --git a/calc-2-9/calcApp/src/aCalcoutRecord.c b/calc-2-9/calcApp/src/aCalcoutRecord.c
index 42da0ea..f4c2b4c 100644
--- a/calc-2-9/calcApp/src/aCalcoutRecord.c
+++ b/calc-2-9/calcApp/src/aCalcoutRecord.c
@@ -893,11 +893,11 @@ static void monitor(acalcoutRecord *pcalc)
 	for (i=0, panew=&pcalc->aa; i<ARRAY_MAX_FIELDS; i++, panew++) {
-		if (*panew && (pcalc->new & (1<<i))) {
+		if (*panew && (pcalc->NEW & (1<<i))) {
 			db_post_events(pcalc, *panew, monitor_mask|DBE_VALUE|DBE_LOG);
-	pcalc->new = 0;
+	pcalc->NEW = 0;
 	/* Check OVAL field */
 	if (pcalc->povl != pcalc->oval) {
@@ -949,7 +949,7 @@ static int fetch_values(acalcoutRecord *pcalc)
 			if (!RTN_SUCCESS(status)) return(status);
 			/* compare new array value with saved value */
 			for (j=0; j<pcalc->nelm; j++) {
-				if (pcalc->paa[j] != (*pavalue)[j]) {pcalc->new |= 1<<i; break;}
+				if (pcalc->paa[j] != (*pavalue)[j]) {pcalc->NEW |= 1<<i; break;}
diff --git a/ipac-2-11/tyGSOctal/tyGSOctal.dbd b/ipac-2-11/tyGSOctal/tyGSOctal.dbd
index 623fda1..3824bdc 100644
--- a/ipac-2-11/tyGSOctal/tyGSOctal.dbd
+++ b/ipac-2-11/tyGSOctal/tyGSOctal.dbd
@@ -1,5 +1,2 @@
-# This driver depends on drvIpac:
-include "drvIpac.dbd"
 # It supplies iocsh commands, so needs a registrar:
 registrar(tyGSOctalRegistrar)
diff --git a/mca-7-1/mcaApp/mcaSrc/mcaRecord.c b/mca-7-1/mcaApp/mcaSrc/mcaRecord.c
index cb6eb78..8d6832b 100644
--- a/mca-7-1/mcaApp/mcaSrc/mcaRecord.c
+++ b/mca-7-1/mcaApp/mcaSrc/mcaRecord.c
@@ -106,7 +106,7 @@
 #include    <recSup.h>
 #include    <recGbl.h>
 #include    <special.h>
 #include    <menuYesNo.h>
 #define GEN_SIZE_OFFSET
@@ -806,8 +806,7 @@ read_data:
     if (!pmca->acqg) {
         /* Use TimeStamp to record end of acquisition */
         recGblGetTimeStamp(pmca);
-        tsStampToText(&pmca->time, TS_TEXT_MONDDYYYY,
-                       pmca->stim);
+        epicsTimeToStrftime(pmca->stim,32,"%b %d, %Y %H:%M:%S.%09f",&pmca->time);
         /* Trim STIM to 25 characters = .001 sec precision */
         pmca->stim[25]='\0';
         MARK(M_STIM);
diff --git a/motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd b/motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd
index 3883b98..f6b21fd 100644
--- a/motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd
+++ b/motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd
@@ -1,4 +1,3 @@
-include "motorRecord.dbd"
 device(motor,VME_IO,devMotorSim,"Motor Simulation")
 driver(motorSim)
 registrar(motorSimRegister)
diff --git a/motor-6-7/motorApp/MotorSrc/motorRecord.cc b/motor-6-7/motorApp/MotorSrc/motorRecord.cc
index 6a17156..66c8be1 100644
--- a/motor-6-7/motorApp/MotorSrc/motorRecord.cc
+++ b/motor-6-7/motorApp/MotorSrc/motorRecord.cc
@@ -169,6 +169,8 @@ HeadURL:        $URL: https://subversion.xor.aps.anl.gov/synApps/motor/tags/R6-7
 #include    <dbEvent.h>
 #include    <devSup.h>
 #include    <math.h>
+#include    "menuYesNo.h"
+#include    "menuOmsl.h"
 #include    "motorRecord.h"
diff --git a/motor-6-7/motorApp/MotorSrc/motorRecord.dbd b/motor-6-7/motorApp/MotorSrc/motorRecord.dbd
index 27c2d9c..849b352 100644
--- a/motor-6-7/motorApp/MotorSrc/motorRecord.dbd
+++ b/motor-6-7/motorApp/MotorSrc/motorRecord.dbd
@@ -29,8 +29,6 @@
 #Modification Log:
-include "menuYesNo.dbd"
 menu(motorDIR) {
         choice(motorDIR_Pos,"Pos")
         choice(motorDIR_Neg,"Neg")
@@ -72,8 +70,6 @@ menu(motorRMOD) {
         choice(motorRMOD_G,"Geometric")
-include "menuOmsl.dbd"
 recordtype(motor) {
         include "dbCommon.dbd"
         field(VERS,DBF_FLOAT) {
diff --git a/motor-6-7/motorApp/OrielSrc/devEMC18011.cc b/motor-6-7/motorApp/OrielSrc/devEMC18011.cc
index bd767ad..980508e 100644
--- a/motor-6-7/motorApp/OrielSrc/devEMC18011.cc
+++ b/motor-6-7/motorApp/OrielSrc/devEMC18011.cc
@@ -40,6 +40,7 @@ Last Modified:	$Date: 2008-03-14 20:19:25 $
 #include <string.h>
 #include <math.h>
 #include "motor.h"
 #include "motordevCom.h"
diff --git a/motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc b/motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc
index c3f79a9..0f19698 100644
--- a/motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc
+++ b/motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc
@@ -40,6 +40,7 @@ Last Modified:	$Date: 2008-03-14 20:20:03 $
 #include <string.h>
 #include "motor.h"
diff --git a/motor-6-7/motorApp/PiSrc/devPIE516.cc b/motor-6-7/motorApp/PiSrc/devPIE516.cc
index e70afd9..54b07a1 100644
--- a/motor-6-7/motorApp/PiSrc/devPIE516.cc
+++ b/motor-6-7/motorApp/PiSrc/devPIE516.cc
@@ -41,6 +41,7 @@ Last Modified:	$Date: 2008-03-14 20:21:37 $
 #include <string.h>
 #include "motor.h"
diff --git a/motor-6-7/motorApp/PiSrc/devPIE710.cc b/motor-6-7/motorApp/PiSrc/devPIE710.cc
index 636eb21..71aeeea 100644
--- a/motor-6-7/motorApp/PiSrc/devPIE710.cc
+++ b/motor-6-7/motorApp/PiSrc/devPIE710.cc
@@ -41,6 +41,7 @@ Last Modified:	$Date: 2008-03-14 20:21:36 $
 #include <string.h>
 #include "motor.h"
diff --git a/motor-6-7/motorApp/PiSrc/devPIE816.cc b/motor-6-7/motorApp/PiSrc/devPIE816.cc
index ff6ca3d..2e1e1d1 100644
--- a/motor-6-7/motorApp/PiSrc/devPIE816.cc
+++ b/motor-6-7/motorApp/PiSrc/devPIE816.cc
@@ -41,6 +41,7 @@ Last Modified:	2007/03/30 20:01:05
 #include <string.h>
 #include "motor.h"
diff --git a/motor-6-7/motorApp/SoftMotorSrc/devSoft.cc b/motor-6-7/motorApp/SoftMotorSrc/devSoft.cc
index 95b2e30..a12bf0e 100644
--- a/motor-6-7/motorApp/SoftMotorSrc/devSoft.cc
+++ b/motor-6-7/motorApp/SoftMotorSrc/devSoft.cc
@@ -58,6 +58,7 @@ NOTES...
 #include	<recSup.h>
 #include	"motor.h"
 #include	"devSoft.h"
diff --git a/motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc b/motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc
index c46b339..d5025d3 100644
--- a/motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc
+++ b/motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc
@@ -41,6 +41,7 @@ Last Modified:	$Date: 2008-03-14 20:23:45 $
 #include <string.h>
 #include <math.h>
 #include "motor.h"
diff --git a/seq-2-1-3/configure/RULES_BUILD b/seq-2-1-3/configure/RULES_BUILD
index c2f1bac..61477b5 100644
--- a/seq-2-1-3/configure/RULES_BUILD
+++ b/seq-2-1-3/configure/RULES_BUILD
@@ -68,6 +68,6 @@ endif
 	$(SNC) $(TARGET_SNCFLAGS) $(SNCFLAGS) $(USR_SNCFLAGS) $(call PATH_FILTER,$<) -o $(@F).tmp
 	$(MV) $(@F).tmp $@
-clean::
+clean:
 	@$(RM) $(SNC_CSRC_FILES)
diff --git a/sscan-2-7/sscanApp/src/Makefile b/sscan-2-7/sscanApp/src/Makefile
index eb7f393..45c7722 100644
--- a/sscan-2-7/sscanApp/src/Makefile
+++ b/sscan-2-7/sscanApp/src/Makefile
@@ -21,11 +21,11 @@ Com_DIR          = $(EPICS_BASE_LIB)
 DBDINC += scanparmRecord
 DBDINC += sscanRecord
+DBDINC += menuSscan
 # <name>.dbd will be created from <name>Include.dbd
 DBD += sscan.dbd
 DBD += sscanSupport.dbd
-DBD += sscanMenu.dbd
 INC += recDynLink.h
diff --git a/sscan-2-7/sscanApp/src/menuSscan.dbd b/sscan-2-7/sscanApp/src/menuSscan.dbd
new file mode 100644
index 0000000..e97cff8
--- /dev/null
+++ b/sscan-2-7/sscanApp/src/menuSscan.dbd
@@ -0,0 +1,95 @@
+menu(sscanNOYES) {
+	choice(sscanNOYES_NO,"NO")
+	choice(sscanNOYES_YES,"YES")
+menu(sscanDSTATE) {
+	choice(sscanDSTATE_UNPACKED, "UNPACKED")
+	choice(sscanDSTATE_TRIG_ARRAY_READ, "TRIG_ARRAY_READ")
+	choice(sscanDSTATE_ARRAY_READ_WAIT, "ARRAY_READ_WAIT")
+	choice(sscanDSTATE_ARRAY_GET_CALLBACK_WAIT, "ARRAY_GET_CALLBACK_WAIT")
+	choice(sscanDSTATE_RECORD_ARRAY_DATA, "RECORD_ARRAY_DATA")
+	choice(sscanDSTATE_SAVE_DATA_WAIT, "SAVE_DATA_WAIT")
+	choice(sscanDSTATE_PACKED, "PACKED")
+	choice(sscanDSTATE_POSTED, "POSTED")
+menu(sscanLINKWAIT) {
+	choice(sscanLINKWAIT_YES,"Wait")
+	choice(sscanLINKWAIT_NO,"NoWait")
+menu(sscanP1SM) {
+	choice(sscanP1SM_Linear,"LINEAR")
+	choice(sscanP1SM_Table,"TABLE")
+	choice(sscanP1SM_On_The_Fly,"FLY")
+menu(sscanFPTS) {
+	choice(sscanFPTS_No,"NO")
+	choice(sscanFPTS_Freeze,"FREEZE")
+menu(sscanFFO) {
+	choice(sscanFFO_Use_F_Flags,"USE F-FLAGS")
+	choice(sscanFFO_Override,"OVERRIDE")
+menu(sscanPASM) {
+	choice(sscanPASM_Stay,"STAY")
+	choice(sscanPASM_Start_Pos,"START POS")
+	choice(sscanPASM_Prior_Pos,"PRIOR POS")
+	choice(sscanPASM_Peak_Pos,"PEAK POS")
+	choice(sscanPASM_Valley_Pos,"VALLEY POS")
+	choice(sscanPASM_RisingEdge_Pos,"+EDGE POS")
+	choice(sscanPASM_FallingEdge_Pos,"-EDGE POS")
+	choice(sscanPASM_COM,"CNTR OF MASS")
+menu(sscanP1AR) {
+	choice(sscanP1AR_Absolute,"ABSOLUTE")
+	choice(sscanP1AR_Relative,"RELATIVE")
+menu(sscanP1NV) {
+	choice(sscanP1NV_PV_OK,"PV OK")
+	choice(sscanP1NV_No_PV,"No PV")
+	choice(sscanP1NV_PV_NoRead,"PV NoRead")
+	choice(sscanP1NV_PV_xxx,"PV illegal1")
+	choice(sscanP1NV_PV_NoWrite,"PV NoWrite")
+	choice(sscanP1NV_PV_yyy,"PV illegal2")
+	choice(sscanP1NV_PV_NC,"PV BAD")
+menu(sscanPAUS) {
+	choice(sscanPAUS_Go,"GO")
+	choice(sscanPAUS_Pause,"PAUSE")
+menu(sscanFAZE) {
+	choice(sscanFAZE_IDLE,"IDLE")
+	choice(sscanFAZE_INIT_SCAN,"INIT_SCAN")
+	choice(sscanFAZE_BEFORE_SCAN,"DO:BEFORE_SCAN")
+	choice(sscanFAZE_BEFORE_SCAN_WAIT,"WAIT:BEFORE_SCAN")
+	choice(sscanFAZE_MOVE_MOTORS,"MOVE_MOTORS")
+	choice(sscanFAZE_CHECK_MOTORS,"WAIT:MOTORS")
+	choice(sscanFAZE_TRIG_DETCTRS,"TRIG_DETCTRS")
+	choice(sscanFAZE_READ_DETCTRS,"WAIT:DETCTRS")
+	choice(sscanFAZE_RETRACE_MOVE,"RETRACE_MOVE")
+	choice(sscanFAZE_RETRACE_WAIT,"WAIT:RETRACE")
+	choice(sscanFAZE_AFTER_SCAN_DO,"DO:AFTER_SCAN")
+	choice(sscanFAZE_AFTER_SCAN_WAIT,"WAIT:AFTER_SCAN")
+	choice(sscanFAZE_SCAN_DONE,"SCAN_DONE")
+	choice(sscanFAZE_SCAN_PENDING,"SCAN_PENDING")
+	choice(sscanFAZE_PREVIEW,"PREVIEW")
+	choice(sscanFAZE_RECORD_SCALAR_DATA,"RECORD SCALAR DATA")
+menu(sscanACQM) {
+	choice(sscanACQM_NORMAL,"NORMAL")
+	choice(sscanACQM_ACC,"ACCUMULATE")
+	choice(sscanACQM_ADD,"ADD TO PREV")
+menu(sscanACQT) {
+	choice(sscanACQT_SCALAR,"SCALAR")
+	choice(sscanACQT_1D_ARRAY,"1D ARRAY")
+menu(sscanCMND) {
+	choice(sscanCMND_CLEAR_MSG,"Clear msg")
+	choice(sscanCMND_CHECK_LIMITS,"Check limits")
+	choice(sscanCMND_PREVIEW_SCAN,"Preview scan")
+	choice(sscanCMND_CLEAR_ALL_PVS,"Clear all PV's")
+	choice(sscanCMND_CLEAR_POS_PVS_ETC,"Clear pos PV's, etc")
+	choice(sscanCMND_CLEAR_POS_PVS,"Clear pos PV's")
+	choice(sscanCMND_CLEAR_POS_RDBK_PVS_ETC,"Clear pos&rdbk PV's, etc")
+	choice(sscanCMND_CLEAR_POS_RDBK_PVS,"Clear pos&rdbk PV's")
diff --git a/sscan-2-7/sscanApp/src/recDynLink.c b/sscan-2-7/sscanApp/src/recDynLink.c
index 50e8045..9f2db3a 100644
--- a/sscan-2-7/sscanApp/src/recDynLink.c
+++ b/sscan-2-7/sscanApp/src/recDynLink.c
@@ -40,13 +40,13 @@ of this distribution.
 #include <taskwd.h>
 #include <dbDefs.h>
+#include <dbAddr.h>
 #include <epicsPrint.h>
 #include <db_access.h>
 #include <db_access_routines.h>
 #include <cadef.h>
 #include <caerr.h>
 #include <caeventmask.h>
 #include <errlog.h>
 #include <epicsExit.h>
@@ -177,7 +177,7 @@ long epicsShareAPI recDynLinkAddInput(recDynLink *precDynLink,char *pvname,
 		printf("recDynLinkAddInput: pvname is blank\n");
 		return(-1);
-	if (options&rdlDBONLY  && db_name_to_addr(pvname,&dbaddr)) return(-1);
+	if (options&rdlDBONLY  && dbNameToAddr(pvname,&dbaddr)) return(-1);
 	if (!inpTaskId) recDynLinkStartTasks();
 	if (precDynLink->pdynLinkPvt) {
 		if (recDynLinkDebug > 10)
@@ -230,7 +230,7 @@ long epicsShareAPI recDynLinkAddOutput(recDynLink *precDynLink,char *pvname,
 		printf("recDynLinkAddOutput: pvname is empty\n");
 		return(-1);
 	if (!outTaskId) recDynLinkStartTasks();
diff --git a/sscan-2-7/sscanApp/src/recDynLink.h b/sscan-2-7/sscanApp/src/recDynLink.h
index 2747cdc..69e8655 100644
--- a/sscan-2-7/sscanApp/src/recDynLink.h
+++ b/sscan-2-7/sscanApp/src/recDynLink.h
@@ -12,7 +12,9 @@ of this distribution.
 #ifndef INCrecDynLinkh
 #define INCrecDynLinkh
+#include <epicsTime.h>
+#include <shareLib.h>
 typedef struct recDynLink{
 	void	*puserPvt;
 	void	*pdynLinkPvt;
diff --git a/sscan-2-7/sscanApp/src/saveData.c b/sscan-2-7/sscanApp/src/saveData.c
index 4c6ebb6..52e43fe 100644
--- a/sscan-2-7/sscanApp/src/saveData.c
+++ b/sscan-2-7/sscanApp/src/saveData.c
@@ -187,7 +187,6 @@ extern STATUS nfsUnmount(char *localName);
 #include <cadef.h>
 #include <epicsMessageQueue.h>
diff --git a/sscan-2-7/sscanApp/src/scanparmRecord.dbd b/sscan-2-7/sscanApp/src/scanparmRecord.dbd
index ef5a5e2..ba447e1 100644
--- a/sscan-2-7/sscanApp/src/scanparmRecord.dbd
+++ b/sscan-2-7/sscanApp/src/scanparmRecord.dbd
@@ -1,4 +1,3 @@
-include "sscanMenu.dbd"
 recordtype(scanparm) {
diff --git a/sscan-2-7/sscanApp/src/sscanMenu.dbd b/sscan-2-7/sscanApp/src/sscanMenu.dbd
deleted file mode 100644
index e97cff8..0000000
--- a/sscan-2-7/sscanApp/src/sscanMenu.dbd
+++ /dev/null
@@ -1,95 +0,0 @@
-menu(sscanNOYES) {
-	choice(sscanNOYES_NO,"NO")
-	choice(sscanNOYES_YES,"YES")
-menu(sscanDSTATE) {
-	choice(sscanDSTATE_UNPACKED, "UNPACKED")
-	choice(sscanDSTATE_TRIG_ARRAY_READ, "TRIG_ARRAY_READ")
-	choice(sscanDSTATE_ARRAY_READ_WAIT, "ARRAY_READ_WAIT")
-	choice(sscanDSTATE_ARRAY_GET_CALLBACK_WAIT, "ARRAY_GET_CALLBACK_WAIT")
-	choice(sscanDSTATE_RECORD_ARRAY_DATA, "RECORD_ARRAY_DATA")
-	choice(sscanDSTATE_SAVE_DATA_WAIT, "SAVE_DATA_WAIT")
-	choice(sscanDSTATE_PACKED, "PACKED")
-	choice(sscanDSTATE_POSTED, "POSTED")
-menu(sscanLINKWAIT) {
-	choice(sscanLINKWAIT_YES,"Wait")
-	choice(sscanLINKWAIT_NO,"NoWait")
-menu(sscanP1SM) {
-	choice(sscanP1SM_Linear,"LINEAR")
-	choice(sscanP1SM_Table,"TABLE")
-	choice(sscanP1SM_On_The_Fly,"FLY")
-menu(sscanFPTS) {
-	choice(sscanFPTS_No,"NO")
-	choice(sscanFPTS_Freeze,"FREEZE")
-menu(sscanFFO) {
-	choice(sscanFFO_Use_F_Flags,"USE F-FLAGS")
-	choice(sscanFFO_Override,"OVERRIDE")
-menu(sscanPASM) {
-	choice(sscanPASM_Stay,"STAY")
-	choice(sscanPASM_Start_Pos,"START POS")
-	choice(sscanPASM_Prior_Pos,"PRIOR POS")
-	choice(sscanPASM_Peak_Pos,"PEAK POS")
-	choice(sscanPASM_Valley_Pos,"VALLEY POS")
-	choice(sscanPASM_RisingEdge_Pos,"+EDGE POS")
-	choice(sscanPASM_FallingEdge_Pos,"-EDGE POS")
-	choice(sscanPASM_COM,"CNTR OF MASS")
-menu(sscanP1AR) {
-	choice(sscanP1AR_Absolute,"ABSOLUTE")
-	choice(sscanP1AR_Relative,"RELATIVE")
-menu(sscanP1NV) {
-	choice(sscanP1NV_PV_OK,"PV OK")
-	choice(sscanP1NV_No_PV,"No PV")
-	choice(sscanP1NV_PV_NoRead,"PV NoRead")
-	choice(sscanP1NV_PV_xxx,"PV illegal1")
-	choice(sscanP1NV_PV_NoWrite,"PV NoWrite")
-	choice(sscanP1NV_PV_yyy,"PV illegal2")
-	choice(sscanP1NV_PV_NC,"PV BAD")
-menu(sscanPAUS) {
-	choice(sscanPAUS_Go,"GO")
-	choice(sscanPAUS_Pause,"PAUSE")
-menu(sscanFAZE) {
-	choice(sscanFAZE_IDLE,"IDLE")
-	choice(sscanFAZE_INIT_SCAN,"INIT_SCAN")
-	choice(sscanFAZE_BEFORE_SCAN,"DO:BEFORE_SCAN")
-	choice(sscanFAZE_BEFORE_SCAN_WAIT,"WAIT:BEFORE_SCAN")
-	choice(sscanFAZE_MOVE_MOTORS,"MOVE_MOTORS")
-	choice(sscanFAZE_CHECK_MOTORS,"WAIT:MOTORS")
-	choice(sscanFAZE_TRIG_DETCTRS,"TRIG_DETCTRS")
-	choice(sscanFAZE_READ_DETCTRS,"WAIT:DETCTRS")
-	choice(sscanFAZE_RETRACE_MOVE,"RETRACE_MOVE")
-	choice(sscanFAZE_RETRACE_WAIT,"WAIT:RETRACE")
-	choice(sscanFAZE_AFTER_SCAN_DO,"DO:AFTER_SCAN")
-	choice(sscanFAZE_AFTER_SCAN_WAIT,"WAIT:AFTER_SCAN")
-	choice(sscanFAZE_SCAN_DONE,"SCAN_DONE")
-	choice(sscanFAZE_SCAN_PENDING,"SCAN_PENDING")
-	choice(sscanFAZE_PREVIEW,"PREVIEW")
-	choice(sscanFAZE_RECORD_SCALAR_DATA,"RECORD SCALAR DATA")
-menu(sscanACQM) {
-	choice(sscanACQM_NORMAL,"NORMAL")
-	choice(sscanACQM_ACC,"ACCUMULATE")
-	choice(sscanACQM_ADD,"ADD TO PREV")
-menu(sscanACQT) {
-	choice(sscanACQT_SCALAR,"SCALAR")
-	choice(sscanACQT_1D_ARRAY,"1D ARRAY")
-menu(sscanCMND) {
-	choice(sscanCMND_CLEAR_MSG,"Clear msg")
-	choice(sscanCMND_CHECK_LIMITS,"Check limits")
-	choice(sscanCMND_PREVIEW_SCAN,"Preview scan")
-	choice(sscanCMND_CLEAR_ALL_PVS,"Clear all PV's")
-	choice(sscanCMND_CLEAR_POS_PVS_ETC,"Clear pos PV's, etc")
-	choice(sscanCMND_CLEAR_POS_PVS,"Clear pos PV's")
-	choice(sscanCMND_CLEAR_POS_RDBK_PVS_ETC,"Clear pos&rdbk PV's, etc")
-	choice(sscanCMND_CLEAR_POS_RDBK_PVS,"Clear pos&rdbk PV's")
diff --git a/sscan-2-7/sscanApp/src/sscanRecord.c b/sscan-2-7/sscanApp/src/sscanRecord.c
index dc655af..145575f 100644
--- a/sscan-2-7/sscanApp/src/sscanRecord.c
+++ b/sscan-2-7/sscanApp/src/sscanRecord.c
@@ -328,6 +328,7 @@
 #include	"recDynLink.h"
 #include "epicsExport.h"
+#include "menuSscan.h"
 #include "sscanRecord.h"
diff --git a/sscan-2-7/sscanApp/src/sscanRecord.dbd b/sscan-2-7/sscanApp/src/sscanRecord.dbd
index c997b55..e44b773 100644
--- a/sscan-2-7/sscanApp/src/sscanRecord.dbd
+++ b/sscan-2-7/sscanApp/src/sscanRecord.dbd
@@ -1,4 +1,3 @@
 recordtype(sscan) {
 	field(VERS,DBF_DOUBLE) {
diff --git a/sscan-2-7/sscanApp/src/sscanSupport.dbd b/sscan-2-7/sscanApp/src/sscanSupport.dbd
index 8bdb44d..db44d4d 100644
--- a/sscan-2-7/sscanApp/src/sscanSupport.dbd
+++ b/sscan-2-7/sscanApp/src/sscanSupport.dbd
@@ -3,6 +3,7 @@
 include "scanparmRecord.dbd"
 include "sscanRecord.dbd"
+include "menuSscan.dbd"
 # DEVICE SUPPORT
diff --git a/std-3-1/stdApp/src/devTimeOfDay.c b/std-3-1/stdApp/src/devTimeOfDay.c
index ad60134..3199302 100644
--- a/std-3-1/stdApp/src/devTimeOfDay.c
+++ b/std-3-1/stdApp/src/devTimeOfDay.c
@@ -62,7 +62,6 @@
 #include "dbCommon.h"
 #include "stringinRecord.h"
 #include "aiRecord.h"
-#include "tsDefs.h"
 #include "epicsEvent.h"
 #include "epicsSignal.h"
 #include "epicsString.h"
@@ -121,10 +120,12 @@ static long createString(psi)
         recGblGetTimeStamp(psi);	/* get time stamp NOW */
         if(psi->phas) {
-            tsStampToText(&psi->time, TS_TEXT_MMDDYY, psi->val);
+            /*OLD tsStampToText(&psi->time, TS_TEXT_MMDDYY, psi->val);*/
+	    epicsTimeToStrftime(psi->val, 28, "%m/%d/%y %H:%M:%S.%09f", &psi->time);
         else {
-            tsStampToText(&psi->time, TS_TEXT_MONDDYYYY, psi->val);
+            /*OLD tsStampToText(&psi->time, TS_TEXT_MONDDYYYY, psi->val);*/
+	    epicsTimeToStrftime(psi->val, 32, "%b %d, %Y %H:%M:%S.%09f", &psi->time);
         /* truncate string to seconds */
diff --git a/stream-2-5-1/streamDevice/src/AsynDriverInterface.cc b/stream-2-5-1/streamDevice/src/AsynDriverInterface.cc
index 26883ea..62a3642 100644
--- a/stream-2-5-1/streamDevice/src/AsynDriverInterface.cc
+++ b/stream-2-5-1/streamDevice/src/AsynDriverInterface.cc
@@ -22,18 +22,9 @@
 #include "StreamError.h"
 #include "StreamBuffer.h"
-#ifdef EPICS_3_14
 #include <epicsTimer.h>
-#else
-#include <assert.h>
-#include <wdLib.h>
-#include <sysLib.h>
-extern "C" {
-#include <callback.h>
-#endif
 #include <asynDriver.h>
 #include <asynOctet.h>
@@ -134,9 +125,7 @@ static const char* eomReasonStr[] = {
 class AsynDriverInterface : StreamBusInterface
-#ifdef EPICS_3_14
  , epicsTimerNotify
-#endif
     asynUser* pasynUser;
     asynCommon* pasynCommon;
@@ -164,13 +153,8 @@ class AsynDriverInterface : StreamBusInterface
     const char* outputBuffer;
     size_t outputSize;
     int peeksize;
-#ifdef EPICS_3_14
     epicsTimerQueueActive* timerQueue;
     epicsTimer* timer;
-#else
-    WDOG_ID timer;
-    CALLBACK timeoutCallback;
-#endif
     AsynDriverInterface(Client* client);
     ~AsynDriverInterface();
@@ -189,12 +173,8 @@ class AsynDriverInterface : StreamBusInterface
     bool disconnectRequest();
     void finish();
-#ifdef EPICS_3_14
     // epicsTimerNotify methods
     epicsTimerNotify::expireStatus expire(const epicsTime &);
-#else
-    static void expire(CALLBACK *pcallback);
-#endif
     // local methods
     void timerExpired();
@@ -211,21 +191,10 @@ class AsynDriverInterface : StreamBusInterface
             (StreamBusInterface::priority());
     void startTimer(double timeout) {
-#ifdef EPICS_3_14
         timer->start(*this, timeout);
-#else
-        callbackSetPriority(priority(), &timeoutCallback);
-        wdStart(timer, (int)((timeout+1)*sysClkRateGet())-1,
-            reinterpret_cast<FUNCPTR>(callbackRequest),
-            reinterpret_cast<int>(&timeoutCallback));
-#endif
     void cancelTimer() {
-#ifdef EPICS_3_14
         timer->cancel();
-#else
-        wdCancel(timer);
-#endif
     // asynUser callback functions
@@ -263,16 +232,10 @@ AsynDriverInterface(Client* client) : StreamBusInterface(client)
         handleTimeout);
     assert(pasynUser);
     pasynUser->userPvt = this;
-#ifdef EPICS_3_14
     timerQueue = &epicsTimerQueueActive::allocate(true);
     assert(timerQueue);
     timer = &timerQueue->createTimer();
     assert(timer);
-#else
-    timer = wdCreate();
-    callbackSetCallback(expire, &timeoutCallback);
-    callbackSetUser(this, &timeoutCallback);
-#endif
 AsynDriverInterface::
@@ -306,12 +269,8 @@ AsynDriverInterface::
     // Now, no handler is running any more and none will start.
-#ifdef EPICS_3_14
     timer->destroy();
     timerQueue->release();
-#else
-    wdDelete(timer);
-#endif
     pasynManager->disconnect(pasynUser);
     pasynManager->freeAsynUser(pasynUser);
     pasynUser = NULL;
@@ -1273,22 +1232,12 @@ timerExpired()
-#ifdef EPICS_3_14
 epicsTimerNotify::expireStatus AsynDriverInterface::
     timerExpired();
     return noRestart;
-#else
-void AsynDriverInterface::
-expire(CALLBACK *pcallback)
-    AsynDriverInterface* interface =
-        static_cast<AsynDriverInterface*>(pcallback->user);
-    interface->timerExpired();
-#endif
 bool AsynDriverInterface::
 connectRequest(unsigned long connecttimeout_ms)
diff --git a/stream-2-5-1/streamDevice/src/Makefile b/stream-2-5-1/streamDevice/src/Makefile
index 99d83b1..8d729a7 100644
--- a/stream-2-5-1/streamDevice/src/Makefile
+++ b/stream-2-5-1/streamDevice/src/Makefile
@@ -36,7 +36,7 @@ include $(TOP)/configure/CONFIG
 LIBRARY_DEFAULT = stream
-DBD += $(LIBRARY_DEFAULT).dbd
+#!DBD += $(LIBRARY_DEFAULT).dbd
 ifdef ASYN
 LIB_LIBS += asyn
diff --git a/stream-2-5-1/streamDevice/src/StreamEpics.cc b/stream-2-5-1/streamDevice/src/StreamEpics.cc
index deb5a61..5626a7b 100644
--- a/stream-2-5-1/streamDevice/src/StreamEpics.cc
+++ b/stream-2-5-1/streamDevice/src/StreamEpics.cc
@@ -22,10 +22,6 @@
 #include "devStream.h"
-#ifndef EPICS_3_14
-extern "C" {
-#endif
 #include <ctype.h>
 #include <stdarg.h>
 #include <stdlib.h>
@@ -37,18 +33,6 @@ extern "C" {
 #include <alarm.h>
-#ifndef EPICS_3_14
-#include <semLib.h>
-#include <wdLib.h>
-#include <taskLib.h>
-extern DBBASE *pdbbase;
-} // extern "C"
-#else
 #include <epicsEvent.h>
@@ -68,8 +52,6 @@ epicsShareFunc int epicsShareAPI iocshCmd(const char *command);
-#endif
 #if defined(__vxworks) || defined(vxWorks)
 #include <symLib.h>
 #include <sysSymTbl.h>
@@ -87,25 +69,16 @@ extern "C" void streamRecordProcessCallback(CALLBACK *pcallback);
 extern "C" long streamReload(char* recordname);
 class Stream : protected StreamCore
-#ifdef EPICS_3_14
     , epicsTimerNotify
-#endif
     dbCommon* record;
     struct link *ioLink;
     streamIoFunction readData;
     streamIoFunction writeData;
-#ifdef EPICS_3_14
     epicsTimer* timer;
     epicsMutex mutex;
     epicsEvent initDone;
-#else
-    WDOG_ID timer;
-    SEM_ID mutex;
-    SEM_ID initDone;
-#endif
     StreamBuffer fieldBuffer;
     int status;
     int convert;
@@ -114,13 +87,8 @@ class Stream : protected StreamCore
     CALLBACK commandCallback;
     CALLBACK processCallback;
-#ifdef EPICS_3_14
     expireStatus expire(const epicsTime&);
-#else
-#endif
 // StreamCore methods
     void protocolStartHook();
@@ -166,11 +134,9 @@ public:
 // shell functions ///////////////////////////////////////////////////////
-#ifdef EPICS_3_14
 extern "C" {
 epicsExportAddress(int, streamDebug);
-#endif
 // for subroutine record
 extern "C" long streamReloadSub()
@@ -225,7 +191,6 @@ extern "C" long streamReload(char* recordname)
     return OK;
-#ifdef EPICS_3_14
 static const iocshArg streamReloadArg0 =
     { "recordname", iocshArgString };
 static const iocshArg * const streamReloadArgs[] =
@@ -251,7 +216,6 @@ static void streamRegistrar ()
 extern "C" {
 epicsExportRegistrar(streamRegistrar);
-#endif // EPICS_3_14
 // driver support ////////////////////////////////////////////////////////
@@ -265,7 +229,6 @@ struct stream_drvsup {
     Stream::drvInit
-#ifdef EPICS_3_14
 extern "C" {
 epicsExportAddress(drvet, stream);
@@ -277,22 +240,6 @@ void streamEpicsPrintTimestamp(char* buffer, int size)
     tlen = tm.strftime(buffer, size, "%Y/%m/%d %H:%M:%S.%03f");
     sprintf(buffer+tlen, " %.*s", size-tlen-2, epicsThreadGetNameSelf());
-#else
-void streamEpicsPrintTimestamp(char* buffer, int size)
-    int tlen;
-    char* c;
-    TS_STAMP tm;
-    tsLocalTime (&tm);
-    tsStampToText(&tm, TS_TEXT_MMDDYY, buffer);
-    c = strchr(buffer,'.');
-    if (c) {
-        c[4] = 0;
-    tlen = strlen(buffer);
-    sprintf(buffer+tlen, " %.*s", size-tlen-2, taskName(0));
-#endif
 long Stream::
 report(int interest)
@@ -500,16 +447,8 @@ Stream(dbCommon* _record, struct link *ioLink,
 :record(_record), ioLink(ioLink), readData(readData), writeData(writeData)
     streamname = record->name;
-#ifdef EPICS_3_14
-#else
-    mutex = semMCreate(SEM_INVERSION_SAFE | SEM_Q_PRIORITY);
-    initDone = semBCreate(SEM_Q_FIFO, SEM_EMPTY);
-#endif
     callbackSetCallback(streamExecuteCommand, &commandCallback);
     callbackSetUser(this, &commandCallback);
     callbackSetCallback(streamRecordProcessCallback, &processCallback);
@@ -532,15 +471,10 @@ Stream::
         record->dpvt = NULL;
         debug("~Stream(%s): dpvt cleared\n", name());
-#ifdef EPICS_3_14
     timer->destroy();
     debug("~Stream(%s): timer destroyed\n", name());
     debug("~Stream(%s): timer queue released\n", name());
-#else
-    wdDelete(timer);
-    debug("~Stream(%s): watchdog destroyed\n", name());
-#endif
     releaseMutex();
@@ -635,11 +569,7 @@ initRecord()
     debug("Stream::initRecord %s: waiting for initDone\n",
         name());
-#ifdef EPICS_3_14
     initDone.wait();
-#else
-    semTake(initDone, WAIT_FOREVER);
-#endif
     debug("Stream::initRecord %s: initDone\n",
         name());
@@ -762,21 +692,12 @@ scan(format_t *format, void* value, size_t maxStringSize)
 // epicsTimerNotify virtual method ///////////////////////////////////////
-#ifdef EPICS_3_14
 epicsTimerNotify::expireStatus Stream::
     timerCallback();
     return noRestart;
-#else
-void Stream::
-    Stream* pstream = static_cast<Stream*>(pcallback->user);
-    pstream->timerCallback();
-#endif
 // StreamCore virtual methods ////////////////////////////////////////////
@@ -835,11 +756,7 @@ protocolFinishHook(ProtocolResult result)
     if (flags & InitRun)
-#ifdef EPICS_3_14
         initDone.signal();
-#else
-        semGive(initDone);
-#endif
         return;
@@ -891,14 +808,7 @@ startTimer(unsigned long timeout)
     debug("Stream::startTimer(stream=%s, timeout=%lu) = %f seconds\n",
         name(), timeout, timeout * 0.001);
-#ifdef EPICS_3_14
     timer->start(*this, timeout * 0.001);
-#else
-    wdStart(timer, (timeout+1)*sysClkRateGet()/1000-1,
-#endif
 bool Stream::
@@ -1229,7 +1139,6 @@ matchValue(const StreamFormat& format, const void* fieldaddress)
     return true;
-#ifdef EPICS_3_14
 // Pass command to iocsh
 void streamExecuteCommand(CALLBACK *pcallback)
@@ -1244,24 +1153,6 @@ void streamExecuteCommand(CALLBACK *pcallback)
         pstream->execCallback(StreamIoSuccess);
-#else
-// Pass command to vxWorks shell
-extern "C" int execute(const char *cmd);
-void streamExecuteCommand(CALLBACK *pcallback)
-    if (execute(pstream->outputLine()) != OK)
-        pstream->execCallback(StreamIoFault);
-    else
-        pstream->execCallback(StreamIoSuccess);
-#endif
 bool Stream::
 execute()
@@ -1274,19 +1165,11 @@ execute()
 void Stream::
 lockMutex()
-#ifdef EPICS_3_14
     mutex.lock();
-#else
-    semTake(mutex, WAIT_FOREVER);
-#endif
 void Stream::
 releaseMutex()
-#ifdef EPICS_3_14
     mutex.unlock();
-#else
-    semGive(mutex);
-#endif
diff --git a/stream-2-5-1/streamDevice/srcSynApps/Makefile b/stream-2-5-1/streamDevice/srcSynApps/Makefile
index 4fec9f9..1f62740 100644
--- a/stream-2-5-1/streamDevice/srcSynApps/Makefile
+++ b/stream-2-5-1/streamDevice/srcSynApps/Makefile
@@ -7,8 +7,6 @@ include $(TOP)/configure/CONFIG
 LIBRARY_DEFAULT = streamSynApps
 ifeq ($(LOADABLE_MODULE),YES)
 SRCS += $(LIBRARY_DEFAULT)_registerRecordDeviceDriver.cpp
 endif
diff --git a/stream-2-5-1/streamDevice/streamApp/Makefile b/stream-2-5-1/streamDevice/streamApp/Makefile
index 892becb..3b0e137 100644
--- a/stream-2-5-1/streamDevice/streamApp/Makefile
+++ b/stream-2-5-1/streamDevice/streamApp/Makefile
@@ -47,7 +47,7 @@ endif
 ifneq ($(words $(CALC) $(SYNAPPS)), 0)
 # With synApps scalcout record
 streamApp_DBD += calcSupport.dbd
-streamApp_DBD += streamSynApps.dbd
+#!streamApp_DBD += streamSynApps.dbd
 PROD_LIBS += calc
 # older calc versions require sscan.  So does new version if it was built with
 # sscan
@@ -55,7 +55,7 @@ PROD_LIBS += sscan
 PROD_LIBS_DEFAULT += streamSynApps
 endif
-streamApp_DBD += stream.dbd
+#!streamApp_DBD += stream.dbd
 ifdef PCRE
 LIB_LIBS += pcre
@@ -78,7 +78,7 @@ CPPFLAGS += -DDEBUGFILE=StreamDebug.log
 include $(TOP)/configure/RULES
-clean:: myclean
+clean: myclean
 myclean:
 	$(RM) core* StreamDebug.log
diff --git a/vac-1-4/vacApp/src/devDigitelPump.dbd b/vac-1-4/vacApp/src/devDigitelPump.dbd
index 44224eb..4cf1dad 100644
--- a/vac-1-4/vacApp/src/devDigitelPump.dbd
+++ b/vac-1-4/vacApp/src/devDigitelPump.dbd
@@ -1,2 +1 @@
 device(digitel,	INST_IO, devDigitelPump, "asyn DigitelPump")
-include "asyn.dbd"
diff --git a/vac-1-4/vacApp/src/devVacSen.dbd b/vac-1-4/vacApp/src/devVacSen.dbd
index ccc1de2..8c4a405 100644
--- a/vac-1-4/vacApp/src/devVacSen.dbd
+++ b/vac-1-4/vacApp/src/devVacSen.dbd
@@ -1,2 +1 @@
 device(vs,	INST_IO,	devVacSen,	"asyn VacSen")
-include "asyn.dbd"
diff --git a/xxx-5-6/xxxApp/src/Makefile b/xxx-5-6/xxxApp/src/Makefile
index 07d1f5b..f0077ce 100644
--- a/xxx-5-6/xxxApp/src/Makefile
+++ b/xxx-5-6/xxxApp/src/Makefile
@@ -140,9 +140,11 @@ endif
 ifneq (,$(findstring linux, $(T_A)))
 	DBD  += iocxxxLinux.dbd
 	iocxxxLinux_DBD += xxxCommonInclude.dbd
-	iocxxxLinux_DBD += ADSupport.dbd  NDFileNetCDF.dbd
+	#!iocxxxLinux_DBD += ADSupport.dbd  NDFileNetCDF.dbd
+	iocxxxLinux_DBD += ADSupport.dbd
 	xxx_LIBS_Linux += ADBase NDPlugin netCDF
-	iocxxxLinux_DBD += simDetectorSupport.dbd commonDriverSupport.dbd
+	#!iocxxxLinux_DBD += simDetectorSupport.dbd commonDriverSupport.dbd
+	iocxxxLinux_DBD += simDetectorSupport.dbd NDPluginSupport.dbd
 	xxx_LIBS_Linux += simDetector
 	# If your host supports libpcap and libnet and you want to build Canberra network
@@ -161,7 +163,7 @@ ifneq (,$(findstring linux, $(T_A)))
 	endif
 	ifdef DEVIOCSTATS
-		iocxxxLinux_DBD += devIocStats.dbd iocAdmin.dbd
+		iocxxxLinux_DBD += devIocStats.dbd
 	endif
 endif
diff --git a/xxx-5-6/xxxApp/src/xxxCommonInclude.dbd b/xxx-5-6/xxxApp/src/xxxCommonInclude.dbd
index 767f6e3..09c4fda 100644
--- a/xxx-5-6/xxxApp/src/xxxCommonInclude.dbd
+++ b/xxx-5-6/xxxApp/src/xxxCommonInclude.dbd
@@ -56,12 +56,10 @@ include "devSPiiPlus.dbd"
 include "devSmartMotorMotor.dbd"
 include "devSoftMotor.dbd"
 include "devThorLabs.dbd"
 include "motorSimSupport.dbd"
 # seq
 include "devSequencer.dbd"
 # stream
-include "stream.dbd"
-include "streamSynApps.dbd"
+#include "streamApp.dbd"
EPICS Base version 3.15.0.1 released Andrew Johnson
Re: EPICS Base version 3.15.0.1 released Anze Zagar
Prev: Re: Cross-compilation, static build, etc J. Lewis Muir
Next: OPC with binary out records pthomas
Prev: Re: EPICS Base version 3.15.0.1 released Eric Norum
Next: Re: EPICS Base version 3.15.0.1 released Ron Sluiter
