Subject: RE: How to profile an EPICS application on Linux
To: Guy Jennings <[email protected]>, Mark Rivers <[email protected]>
Date: Tue, 11 Sep 2012 03:48:59 +0000
I used Intel VTune on Linux. It was pretty helpful  for profiling the channel archiver.
-Nikolay
From: [email protected] [[email protected]] on behalf of Guy Jennings [[email protected]]
Sent: Monday, September 10, 2012 8:23 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: How to profile an EPICS application on Linux
Might be worth taking a look at the Intel Thread Profiler for Linux -
I've used the Windows version and it is excellent
at showing threading problems.  It's quite expensive, but there is a
30 day evaluation version.
On Sep 10, 2012, at 6:03 PM, Mark Rivers wrote:
> Thanks for the suggestion, perf record and perf report work fine.
> The results are interesting.  10% of the time is spend in the
> pthread_mutex code.
>  5.38%  quadEMTestApp  libpthread-2.14.1.so  [.]
> __pthread_mutex_unlock_usercnt
>  4.34%  quadEMTestApp  libpthread-2.14.1.so  [.]
> pthread_mutex_lock
>        a
>  2.36%  quadEMTestApp  quadEMTestApp         [.]
> getAddr
>        a
>  2.27%  quadEMTestApp  quadEMTestApp         [.]
> __i686
> .get_pc_thunk
> .bx
>        a
>  2.17%  quadEMTestApp  [kernel.kallsyms]     [k]
> _raw_spin_lock
>        a
>  1.98%  quadEMTestApp  quadEMTestApp         [.]
> paramList::int32Callback(int,
> int
> )        a
>  1.95%  quadEMTestApp  libpthread-2.14.1.so  [.]
> pthread_cond_signal
> @@GLIBC_2.3.2
>        a
>  1.95%  quadEMTestApp  [kernel.kallsyms]     [k]
> ia32_syscall
>        a
>  1.79%  quadEMTestApp  [kernel.kallsyms]     [k]
> __audit_syscall_exit
>        a
>  1.55%  quadEMTestApp  quadEMTestApp         [.]
> epicsMutexLock
>        a
>  1.53%  quadEMTestApp  [kernel.kallsyms]     [k]
> resched_task
>        a
>  1.47%  quadEMTestApp  quadEMTestApp         [.]
> epicsMutexOsdLock
>        a
>  1.44%  quadEMTestApp  [kernel.kallsyms]     [k]
> do_futex
>        a
>  1.41%  quadEMTestApp  quadEMTestApp         [.]
> paramList
> ::getParameter
> (int
> )        a
>  1.35%  quadEMTestApp  [kernel.kallsyms]     [k]
> __schedule
>        a
>  1.29%  quadEMTestApp  quadEMTestApp         [.]
> getTraceMask
>        a
>  1.29%  quadEMTestApp  [kernel.kallsyms]     [k]
> update_cfs_shares
>        a
>  1.24%  quadEMTestApp  [kernel.kallsyms]     [k]
> update_curr
>        a
>  1.24%  quadEMTestApp  quadEMTestApp         [.]
> portThread
>        a
>  1.23%  quadEMTestApp  quadEMTestApp         [.]
> epicsMutexUnlock
>        a
>  1.23%  quadEMTestApp  [kernel.kallsyms]     [k]
> native_write_msr_safe
>        a
>  1.20%  quadEMTestApp  [kernel.kallsyms]     [k]
> select_task_rq_fair
>        a
> try_to_wake_up
>        a
>  1.12%  quadEMTestApp  [kernel.kallsyms]     [k]
> update_rq_clock
>        a
> futex_wait
>        a
>  1.09%  quadEMTestApp  [kernel.kallsyms]     [k]
> update_cfs_load
>        a
>  1.08%  quadEMTestApp  [kernel.kallsyms]     [k]
> device_not_available
>        a
>  0.92%  quadEMTestApp  quadEMTestApp         [.]
> drvQuadEM
> ::computePositions
> (int
> *)        a
>  0.91%  quadEMTestApp  [kernel.kallsyms]     [k]
> hash_futex
>        a
> futex_wake
>        a
>  0.89%  quadEMTestApp  [kernel.kallsyms]     [k]
> plist_add
>        a
>  0.87%  quadEMTestApp  [kernel.kallsyms]     [k]
> ia32_sysenter_target
>        a
>  0.83%  quadEMTestApp  [vdso]                [.]
> 0xf77ac421
>        a
>  0.83%  quadEMTestApp  libpthread-2.14.1.so  [.]
> pthread_cond_wait
> @@GLIBC_2.3.2
>        a
>  0.81%  quadEMTestApp  [kernel.kallsyms]     [k] effective_load
> Mark
> -----Original Message-----
> From: J. Lewis Muir [mailto:[email protected]]
> Sent: Monday, September 10, 2012 5:37 PM
> To: Mark Rivers
> On 9/10/12 5:21 PM, Mark Rivers wrote:
>> Here is the output of "time" when running it in a mode where "top"
>> showed the application using about 95% of a single CPU (on a 16
>> core system).  This is with my calculations enabled.
>> 23.547u 16.516s 0:52.39 76.4%   0+0k 0+24io 0pf+0w
>> This is the output of time when the calculations are disabled and
>> top shows about 80% CPU in my application.
>> Disabling my calculations:
>> 11.401u 8.008s 0:27.60 70.2%    0+0k 0+8io 0pf+0w
>> So it spends a substantial amount of CPU time in both User Mode and
>> Kernel Mode.
> Hi, Mark.
> OK, then I don't know what's going on.  Maybe gprof has problems
> with threaded programs (??).
> I'm really not answering your question now, but another idea: Is
> your Linux system new enough that you have the perf subsystem
> available?  You could try that instead:
> $ perf record ../../bin/linux-x86/quadEMTestApp
> $ perf report
> Lewis
How to profile an EPICS application on Linux Mark Rivers
Re: How to profile an EPICS application on Linux J. Lewis Muir
RE: How to profile an EPICS application on Linux Mark Rivers
Re: How to profile an EPICS application on Linux Guy Jennings
Prev: Re: How to profile an EPICS application on Linux Guy Jennings
Next: GigE Vision & GeniCam standard SDK (areaDetector) Ahed Aladwan
Next: Re: How to profile an EPICS application on Linux John A. Priller
