1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: What I learned today...
To: [email protected]
Date: Thu, 28 Feb 2013 10:51:51 -0500
On 02/28/2013 09:57 AM, Benjamin Franksen wrote:
On Thursday, February 28, 2013 09:41:14 Michael Davidsaver wrote:
Makefiles are so much fun...
If you don't like creating marker files (which must be cleaned) you can
also do:
one two three: create_some_files.pl
     ./create_some_files.pl
three: two
two: one
This creates a dependency chain forcing sequential execution.
Yes, but...
(1) The script can be called more often than necessary:
I don't think this is the case as long as the command './create_some_files.pl' creates all three files (which I assume it what you intended).
It is my understanding that the existence and timestamp of the target file are checked immediately after all dependent rules have run, and not when the dependency tree is computed. This is why these rules work when with '-j1'.
(2) Getting the additional sequentializing dependencies right is harder and
the result less obvious.
I certainly can't argue with this.
Again, think of a generated list of many, many files
(in our case the script creates 692 targets).
Wow. I agree that what I describe would not scale to this. I've typically used this for code generators which produce two or three output files.
Re: What I learned today... Andrew Johnson
Re: What I learned today... Benjamin Franksen
Re: What I learned today... Michael Davidsaver
Prev: JCA Error Lucas José
Next: RE: JCA Error Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: What I learned today... Benjamin Franksen
Next: Re: What I learned today... Andrew Johnson
