1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: What I learned today...
To: [email protected]
Date: Fri, 01 Mar 2013 10:42:12 -0500
On 03/01/2013 06:55 AM, Benjamin Franksen wrote:
On Thursday, February 28, 2013 10:51:51 Michael Davidsaver wrote:
I don't think this is the case as long as the command
'./create_some_files.pl' creates all three files (which I assume it what
you intended).
I attached a simple test example that exhibits the above behaviour.
You are correct. It seems that gnumake does _not_ test for the existence of the target file immediately before executing the rule. I'm going to refrain from guessing at the logic behind this.
http://www.cmcrossroads.com/article/rules-multiple-outputs-gnu-make
What I learned today... Benjamin Franksen
Re: What I learned today... Benjamin Franksen
Re: What I learned today... Michael Davidsaver
Prev: Re: What I learned today... Benjamin Franksen
Next: RE: Crystal Logic goniometer Myers, Stuart F
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: seq: benign(?) error message when building with R3.15 Benjamin Franksen
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
