1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Error message control in StreamDevice
To: Dirk Zimoch <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Wed, 19 Jun 2013 03:00:08 +0000
Hi Dirk,
StreamDevice is primarily (exclusively?) used as device support for asyn drivers with EPICS.  As such, however, it does not follow the asyn "rules" for device support.  This is from the asynDriver Manual at http://www.aps.anl.gov/epics/modules/soft/asyn/R4-21/asynDriver.html
In order for the trace facility to perform properly; device support and all drivers must use the trace facility. Device and driver support can directly call the asynTrace methods. The asynPrint and asynPrintIO macros are provided so that it is easier for device/driver support. Support can have calls like:
    asynPrint(pasynUser,ASYN_TRACE_FLOW,"%s Calling queueRequest\n",
        someName);
StreamDevice does not use the asynTrace facility for error messages.  This has unfortunate consequences.  This is the output from an EPICS IOC that talks to a TCP/IP device with StreamDevice.  In this case the device happens to not be connected to the network.
2013/06/18 20:57:01.529 PACE5000 13PACE5000:PC1:Effort_RBV: Protocol aborted
2013/06/18 20:57:07.541 PACE5000 13PACE5000:PC1:Error_RBV: pasynCommon->connect() failed: Can't connect to 164.54.160.26:5025: No route to host
2013/06/18 20:57:07.541 PACE5000 13PACE5000:PC1:Error_RBV: Protocol aborted
2013/06/18 20:57:10.547 PACE5000 13PACE5000:PC1:Effort_RBV: pasynCommon->connect() failed: Can't connect to 164.54.160.26:5025: No route to host
2013/06/18 20:57:10.547 PACE5000 13PACE5000:PC1:Effort_RBV: Protocol aborted
2013/06/18 20:57:13.553 PACE5000 13PACE5000:PC1:Vent_RBV: pasynCommon->connect() failed: Can't connect to 164.54.160.26:5025: No route to host
2013/06/18 20:57:13.553 PACE5000 13PACE5000:PC1:Vent_RBV: Protocol aborted
2013/06/18 20:57:16.559 PACE5000 13PACE5000:PC1:Slew_RBV: pasynCommon->connect() failed: Can't connect to 164.54.160.26:5025: No route to host
2013/06/18 20:57:16.559 PACE5000 13PACE5000:PC1:Slew_RBV: Protocol aborted
2013/06/18 20:57:19.565 PACE5000 13PACE5000:PC1:Error_RBV: pasynCommon->connect() failed: Can't connect to 164.54.160.26:5025: No route to host
2013/06/18 20:57:19.565 PACE5000 13PACE5000:PC1:Error_RBV: Protocol aborted
2013/06/18 20:57:22.571 PACE5000 13PACE5000:PC1:Vent_RBV: pasynCommon->connect() failed: Can't connect to 164.54.160.26:5025: No route to host
So there is a constant stream of error messages.
If StreamDevice used the asynTrace facility I could very easily turn these messages off with the following command:
asynSetTraceMask PACE5000 0 0
I could also turn them off with an EPICS GUI like medm by setting the ASYN_TRACE_ERROR bit for that port 0 with an asynRecord.
However, I've looked at the documentation for StreamDevice, and also the source code for StreamError.h and StreamError.cc, and there does not appear to beany way to turn off the error messages in StreamDevice.  There is a global variable StreamDebugFile which should allow one to route all StreamDevice error messages to afile.  But that is not what I want, I want to route just the messages for this disconnected device PACE5000.  Furthermore StreamDebugFile appears not to be availble in the iocsh shell?
I looked to see if it would be easy to convert the StreamError class to use asynTrace, and it is not as easy as I hoped because the required pasynUser handle is not available outside the AsynDriverInterface class.
Is there a way to make StreamDevice use the asynTrace facility, so we can get its advantages like enabling/disabling error messages on a per-port basis, routing debug output to a file on a per-port basis, etc.?
If not, then the changes I am considering to asyn to automatically turn off error messages on a disconnected port won't affect StreamDevice messages.
Re: Error message control in StreamDevice Dirk Zimoch
Prev: Re: analog output record - constant DOL Benjamin Franksen
Next: Re: Error message control in StreamDevice Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: configuring RDB archiver from xml files James F Ross
