Hi
again sorry for long delay; you are not forgotten!
On Wednesday, June 12, 2013 12:38:40 J. Lewis Muir wrote:
> On 6/12/13 11:10 AM, Benjamin Franksen wrote:
> > On Monday, June 10, 2013 17:22:12 Carl Lionberger wrote:
> >> Looking at the code in seq_ca.c and seq_if.c, it seems that if a
> >> synchronous pvGet ever fails to get a callback from channel access, the
> >> "get completion timeout" message is set in the channel metadata and all
> >> subsequent attempts to do pvGets on that channel will fail as in the
> >> first
> >> message. The latter occurs because there is a get semaphore for each
> >> channel that the callback is supposed to give.
> >> My thought is that if the callback doesn't come the semaphore should be
> >> released in the same code that sets the "get completion timeout" message.
> > I find it very hard to judge what the correct behaviour is, here.
> > Maybe Jeff can comment?
> >> Or is there something the operator should be able to do, short of
> >> restarting the sequencer?
> > There is not, currently, but I could add something. Maybe letting the
> > programmer explicitly "recover" from timeouts is better than doing it
> > automatically, at least as long as (and assuming that) canceling pvGet
> > requests is not supported by the CA client API.
> I think I've run into Carl's problem before too.
> Could you supply the CA callback with a sequence number that would
> uniquely identify the callback as being for a particular pvGet? This
> way, you could ignore a callback if it arrives for a pvGet that has been
> abandoned.
Right, that's a possibility.
Will look into this and see if I can get something hacked up.
One thing I hate about this is that I happen to know CA already does exactly
that, on the protocol level. It just isn't exposed in the API.
Cheers
Ben Franksen
() ascii ribbon campaign - against html e-mail
/\ www.asciiribbon.org - against proprietary attachm€nts
signature.asc
Description: This is a digitally signed message part.
- Re: pvGet timeout in sequencer 2.1.12 Benjamin Franksen
- pvGet timeout in sequencer 2.1.12 Carl Lionberger
- Re: pvGet timeout in sequencer 2.1.12 J. Lewis Muir
Re: seqLog obsolete / errlog filtering based on source Benjamin Franksen
CSS and Subversion Vigder, Mark
<2013>
2025
<2013>
2025
