1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in errlogRemoveListener
To: [email protected]
Date: Fri, 21 Jun 2013 10:24:29 -0500
Hi Benjamin,
On 2013-06-21 Benjamin Franksen wrote:
> On Friday, June 21, 2013 11:18:07 Benjamin Franksen wrote:
> > The errlog facility provides errlogAddListener, and errlogRemoveListener.
> > Unfortunately, the latter is broken, as there is no way to specify the
> > listener's private data. So if I have two listeners which differ only in
> > their private data (such as when using two instances of feller), then I
> > can only remove them all at once, not each one separately.
Actually errlogRemoveListener() will only delete the *first* listener in the
list that matches (there's a 'break' which stops the loop once it finds a
match).
WARNING: Kludge Ahead!  If feller keeps a list of its own registrations it
could remove all its listeners up to the one it wants to delete and then add
the others back again (but that would change their order in the list, so it
would have to adjust its list accordingly; algorithm testing highly
recommended!).
> > The attached patch file rectifies that by adding an
> > errlogRemoveSingleListener function to the API that allows to remove
> > single instances.
Thanks, I will consider this for the 3.15 branch.
> In the meantime, I wonder how to proceed with the feller module.
> Better ideas would be much appreciated.
You could just register one listener and keep your own list of clients which
that listener traverses when it gets called.  Now you can delete specific
entries at leisure because you own the list.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: Problem in errlogRemoveListener Benjamin Franksen
Prev: Re: help setting up XY table control with EPICS StreamerClass Tim Mooney
Next: Re: help setting up XY table control with EPICS StreamerClass Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem in errlogRemoveListener Benjamin Franksen
Next: Re: Problem in errlogRemoveListener Benjamin Franksen
