1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in errlogRemoveListener
To: <[email protected]>
Date: Fri, 21 Jun 2013 20:12:46 +0200
Am Freitag, 21. Juni 2013, 17:24:29 schrieb Andrew Johnson:
> On 2013-06-21 Benjamin Franksen wrote:
> > On Friday, June 21, 2013 11:18:07 Benjamin Franksen wrote:
> > > The errlog facility provides errlogAddListener, and
> > > errlogRemoveListener. Unfortunately, the latter is broken, as there is
> > > no way to specify the listener's private data. So if I have two
> > > listeners which differ only in their private data (such as when using
> > > two instances of feller), then I can only remove them all at once, not
> > > each one separately.
> > > The attached patch file rectifies that by adding an
> > > errlogRemoveSingleListener function to the API that allows to remove
> > > single instances.
> Thanks, I will consider this for the 3.15 branch.
Cool. However, for 3.15 I propose to change the existing errlogRemoveListener,
instead of adding a new function; I was speculating on the patch being
accepted for 3.14.12.4, which is why I added a new function.
> > In the meantime, I wonder how to proceed with the feller module.
> > Better ideas would be much appreciated.
> You could just register one listener and keep your own list of clients
> which that listener traverses when it gets called.  Now you can delete
> specific entries at leisure because you own the list.
My colleague Götz suggested the same and so this is what I did. Not much of a
problem since I already had such a list. (I needed it so that when the user
gives a file name for which a feller already exists, she gets back the
existing feller, not a new one; fellerCreate will output a warning in this
case, since this is typically not what you want).
It's all implemented in the newly released feller-0.3.
Cheers and thanks to everyone for the valuable feedback.
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachm€nts
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Problem in errlogRemoveListener Andrew Johnson
Problem in errlogRemoveListener Benjamin Franksen
Re: Problem in errlogRemoveListener Benjamin Franksen
Prev: RE: Using all the cores available on modern processors Mark Rivers
Next: Re: help setting up XY table control with EPICS StreamerClass Christian Pauly
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem in errlogRemoveListener Andrew Johnson
Next: Re: Problem in errlogRemoveListener Andrew Johnson
