1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in errlogRemoveListener
To: [email protected]
Date: Fri, 21 Jun 2013 16:32:24 -0500
Hi Benjamin,
On 2013-06-21 Benjamin Franksen wrote:
> Cool. However, for 3.15 I propose to change the existing
>  errlogRemoveListener, instead of adding a new function; I was speculating
>  on the patch being accepted for 3.14.12.4, which is why I added a new
>  function.
I added the ability to delete multiple listeners, and it now returns a count
of the number actually removed.
This version (against 3.15) renames the function and adds a flags argument,
but provides an API-compatible macro for code written against 3.14, plus some
others to give it a simple API.
Comments welcome.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Problem in errlogRemoveListener Benjamin Franksen
Re: Problem in errlogRemoveListener Andrew Johnson
Re: Problem in errlogRemoveListener Benjamin Franksen
Prev: RE: Using all the cores available on modern processors Mark Rivers
Next: Re: Using all the cores available on modern processors Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem in errlogRemoveListener Benjamin Franksen
Next: Re: Problem in errlogRemoveListener Andrew Johnson
