1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AW: [asyn] link already open!
To: Andrew Johnson <[email protected]>, EPICS Tech Talk <[email protected]>, Dirk Zimoch <[email protected]>
Date: Tue, 13 Aug 2013 10:43:06 +0200
Andrew, but can I get away with including base.dbd in the support module? What if it's included in the main IOC for the second time?
Dirk, are you using the dlload command or your own c routine? Could you also elaborate on your "stupid" dbd parser script?
Pavel Maslov, MS
On Mon, Aug 12, 2013 at 9:02 PM, Andrew Johnson <[email protected]> wrote:
On 08/12/2013 01:44 PM, Zimoch Dirk wrote:
Unfortunately it is broken on 3.15 because the new parser is more whimpy.
I would use the word "strict" myself.  The device support is asking it to believe that the named record type will actually exist when the IOC is booted.  Your version believes anything you tell it, the newer 3.15 one is more like a doubting Thomas (or a financial auditor if you prefer, it wants to see real evidence).
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: AW: [asyn] link already open! Andrew Johnson
Re: AW: [asyn] link already open! Dirk Zimoch
[asyn] link already open! Pavel Maslov
RE: [asyn] link already open! Mark Rivers
Re: [asyn] link already open! Pavel Maslov
Re: [asyn] link already open! Dirk Zimoch
AW: [asyn] link already open! Zimoch Dirk
Prev: RE: EtherCAT [SEC=UNOFFICIAL] nick.rees
Next: RE: EtherCAT [SEC=UNOFFICIAL] ronaldo.mercado
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AW: [asyn] link already open! Andrew Johnson
Next: Re: AW: [asyn] link already open! Andrew Johnson
