Hi Pavel,
On 08/13/2013 03:43 AM, Pavel Maslov wrote:
Andrew, but can I get away with including base.dbd in the support
module? What if it's included in the main IOC for the second time?
I haven't tried it and I wouldn't recommend it, that could result in all
the record types, soft device support and other items getting registered
twice, which I suspect might have nasty consequences.
Take a look at the *_registerRecordDeviceDriver.cpp file that gets
generated in your IOC's build directory and see what it is doing. You
could create an equivalent source file to this by hand for the things
that are in each module if you wanted to, but you would have to repeat
that process any time you upgraded a module. You have already
experienced the weird kinds of errors that can occur if you get this
stuff wrong though.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: AW: [asyn] link already open! Pavel Maslov
- [asyn] link already open! Pavel Maslov
- RE: [asyn] link already open! Mark Rivers
- Re: [asyn] link already open! Pavel Maslov
- Re: [asyn] link already open! Dirk Zimoch
- AW: [asyn] link already open! Zimoch Dirk
- Re: AW: [asyn] link already open! Andrew Johnson
RE: EtherCAT [SEC=UNOFFICIAL] ronaldo.mercado
<2013>
2025
<2013>
2025
