You need hardware with proper clock and in particular a hardware circular buffer which you populate with your samples.
Software wise, you read the hardware buffer at a much lower frequency, but fast enough so it doesn't wrap around.
(i.e. set the size of the hardware buffer correctly and use 2 pointers (last data written, last data read))
Read all the new data from the hardware buffer **at once** and append it to your compress record.
What are you sampling and how do you currently intend to do it?
can you lose chunks of data?
Good luck!
Emmanuel
> Date: Tue, 26 Nov 2013 15:20:22 -0800
> From:
[email protected]> To:
[email protected]> Subject: Increasing scan rate to 10 kHz
> Hello,
> I can easily set scan period to 0.01 second by adding:
> choice(menuScan_01_second,".01 second")
> in dbd file.
> What about adding scan period 0.0001 second?
> Similar line:
> choice(menuScan_0001_second,".0001 second")
> doesn't work.
> CLOCKS_PER_SECOND on my 8-core DELL server is 1000000 (running SL5.4).
> What should I do to set scan period to 0.0001 second?
> I need such short period to quickly fill in the circular buffer of
> compress record.
> Thanks,
> Evgeniy
