Nadia.
If you seek help then I suggest you provide as much information
about your situation as possible along with your request.
"I have a problem, please help"
does not give us any clue as to what exactly you were trying to do
and what exactly went wrong. Chances to get a reply increase
if you give more details. At the least, I recommend to attach a
***complete*** log of your failed attempt to build.
Please don't make the common mistake to just copy/paste the
few lines where the actual failure happens. It is very important
that
you provide a complete log because in many cases the cause
for the failure can be determined from information that is
contained
somewhere in the log (but not in the excerpt which the novice
solely believes to be relevant).
Good luck
- Till
On 11/27/2013 12:19 AM, Nadia Gruman wrote:
Hello all,
Is anyone using EPICS with RTEMS 4.11? I am trying to build
it for use with MVME5500, but I'm running into some issues and
wondering if I should use 4.10.
There are compilation issues I ran into on Linux 12.04,
plus there seem to be no rtems addon packages for 4.11 on
their git site.
Thank you,
Nadia Gruman
- Re: EPICS on RTEMS 4.11 Kate Feng
- EPICS on RTEMS 4.11 Nadia Gruman
RE: Increasing scan rate to 10 kHz Emmanuel Mayssat
RE: EpicsSharp issues Bertrand Alain Gregor
<2013>
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
