Hi Brian,
On 03/18/2014 02:57 PM, Brian Bevins wrote:
> Hmm. When I run casr on my ioc, I get back one priority value per
> client, not one per channel. And all of the priorities are currently
> zero. Should this output look different if I were setting priority on a
> per channel basis from the client?
The CA client has to use a separate TCP connection to the server for
each priority, so internally the server groups them by connection and
hence by priority.
For experimental purposes the caget and camonitor programs can be
configured to use a particular priority (-p <prio> where <prio> is 0-99
with 0 as the default & lowest priority). I would suggest setting up one
camonitor of your waveform records with default priority and a second
one with higher priority on the faster channels. If this resolves the
stuttering it tells you that it's probably worth exploring this approach
further.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Prioritizing Channel Access per Record? Brian Bevins
- Prioritizing Channel Access per Record? Brian Bevins
- Re: Prioritizing Channel Access per Record? Ralph Lange
how to ... in CSS BOY? Jemian, Pete R.
RE: Bayer vs RGB1 performance for Prosilica cameras Mark Rivers
<2014>
<2014>
