Amit,
From your original mail, I thought that it was the Windows build
because I found the error directly after a call to 'cl', the Windows
compiler that uses WIN32 include path and very much looks like a Windows
build.
cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\t
sDefs -IC
:\EPICS\base-3-14-12-4\\include\\os\\WIN32 -IC:\EPICS\base-3-14-12-4\\include ..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp
..\..\..\src\libCom\ring\epicsRingPointer.h(93) : error C2664: 'delete' : cannot convert parameter 1 from 'void *volatile * ' to 'void *'
Conversion loses qualifiers
..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling class-template member function '__thiscall epicsRingPointer<void>::~epicsRingPointer<void>(void)'
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
Do you call make with the -j option for parallel builds? In that case
the output may be confusing and it can be hard to set error messages and
commands into relation.
To make things clearer try first to build for the Windows host only and
after that for vxWorks.
If compiling for Windows alone works it is probably a vxWorks compiler
problem.
Concerning the error popup: This is probably a vxWorks cross tools
thing, too. WindRiver is more and more annoying with each new version
and calling the cross tools from make instead of their own environment
is more and more complicated. I think this tool want to check if you
have the proper vxWorks licenses installed. It seems you have to set a
PATH to the lmapi.dll in a config file. I guess all previous attempts to
compile vxWorks 6.9 have been made from Linux, not from Windows. So
setups for Windows may be missing in the config files.
On 30.07.2014 09:08, Amit Chauhan wrote:
Dear Mark,
This is further to our trials of compiling EPICS for 'VxWorks 6.9'
We ran the 'make' from Visual Studio (2010) Command Prompt.
I am attaching following with this mail:
(1) CONFIG_SITE.Common.vxWorksCommon : This is the only file we have
modified.
(2) make_output.txt : output of the make process (with error message
appended at the bottom )
(3) errMsg.jpg : This is a pop-up message we encountered 42 times towards
the end of 'make' . We had to press 'OK' everytime to proceed.
During this trial no changes were made related to the ringPointer.
We would just like to add that when we are buidling EPICS base 3.14.12.4
with Visual Studio 2010 for 'Windows' as target, we are not encountering any
errors.
It is just that when we select 'vxWorks' as target the problems arise.
Amit Chauhan
RRCAT, Indore
- EPICS on VxWorks6.9 Amit Chauhan
- Re: EPICS on VxWorks6.9 Dirk Zimoch
- RE: EPICS on VxWorks6.9 Mark Rivers
- RE: EPICS on VxWorks6.9 Amit Chauhan
<2014>
2025
<2014>
2025
