Hi Ben,
I have tried building the synApps module with seq 2.2.0.1. I am running into some problems that I could not figure out from the release notes:
../MAX_trajectoryScan.st: In function 'seqg_action_maxTrajectoryScan_0_execute':
../MAX_trajectoryScan.st:588:40: error: called object 'seqg_var->time' is not a function
The line with the error, which is in SNL code, not escaped C code, is:
startTime = time(0);
This is the definition of startTime at the start of the SNL code.
/* Note, this should be time_t, but SNL doesn't understand that. This is
* the defininition in vxWorks. */
unsigned long startTime;
The error occurs whether or not the following line is included at the top of the SNL code:
%% #include <time.h>
The next error is:
../MAX_trajectoryScan.st:996:3: error: too few arguments to function 'seq_pvGet'
The offending line is:
seq_pvGet(ssId, pVar->epicsMotorDoneIndex[j], 0);
This is in escaped C code at the end of the file. The program is built with the "+r" option.
The final error is:
/corvette/home/epics/devel/seq-2-2-0-1/bin/linux-x86/snc getFilledBuckets.i -o getFilledBuckets.c
../getFilledBuckets.st:151: error: calling built-in function delay not allowed here
Line 151 is the delay(1.0) statement in the code below:
when((srInjectStatus == NOTINJECTING) &&
(srBeamStatus) == STOREDBEAM) {
delay(1.0); /* 1 sec delay */
Is this error due to this change in 2.2.0:
"Since calling delay outside of the condition of a state transition never had any useful effect, it is now disallowed."
From: [email protected] [[email protected]] on behalf of Benjamin Franksen [[email protected]]
Sent: Monday, August 04, 2014 8:23 AM
To: 'EPICS Techtalk'
Subject: Sequencer 2.2.0
Hi Everyone
I am happy to (finally!) anounce the first public release of the EPICS
Sequencer version 2.2. This release contains many new features, see the
release notes [0] for details. There are also some changes to the
interface between compiler and run-time system, which may cause trouble
when trying to build existing programs, especially ones that heavily
rely on escape to C. I tried to keep the incompatibilities to a minimum,
though, so most programs should build fine with the new version. Details
about this are also in the release notes.
Building on Windows might fail because unfortunately I could not test
that yet.
Please report any problems you notice. I will go on holidays from
Thursday until the end of August, and I will probably not be able to
answer questions during this time, but I promise I'll address all of
them when I come back.
Cheers
Ben
[0] http://www-csr.bessy.de/control/SoftDist/sequencer/ReleaseNotes-2-2.html#release-notes-2-2-0
"Make it so they have to reboot after every typo." â?? Scott Adams
- Re: Sequencer 2.2.0 Andrew Johnson
- Re: Sequencer 2.2.0 Benjamin Franksen
- Sequencer 2.2.0 Benjamin Franksen
Re: st.cmd -- Line 30 -- Command seq not found. Benjamin Franksen
VDCT priya tiwari
<2014>
Sequencer 2.2.0.1 Benjamin Franksen
<2014>
