1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem linking Mclennan stepper motor libraries into x86 IOC app
Date: Fri, 8 Aug 2014 03:00:30 +0000
Dear tech-talkers
We have a x64 machine which is used to cross compile IOC applications for RTEMS, linux-arm and linux-x86.  The creator of this setup has since left our employ, but this system has been plodding along nicely.  However, I have run into a problem when trying to add in support for Mclennan stepper motor controllers.  This example is with motor module R6-5-2 and all that has changed from the production system is the modification of:
../epics/trunk/tandem/tandemApp/src/Makefile
which with addition of two lines referencing the Mclennan database and library is now:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC application
#PROD_Linux = -nil- # not on linux
PROD_DEFAULT = tandem
# tandem.dbd will be created and installed
DBD += tandem.dbd
# tandem.dbd will be made up from these files:
tandem_DBD += base.dbd
# Include dbd files from all support applications:
tandem_DBD += $(ANUNUCLEAR)/src/anunuclear.dbd
tandem_DBD += $(DJRESTORE)/src/djrestore.dbd
tandem_DBD += $(ASYN)/dbd/asyn.dbd
tandem_DBD += $(ASYN)/dbd/asynRecord.dbd
tandem_DBD += $(MOTOR)/dbd/motorRecord.dbd
tandem_DBD += $(MOTOR)/dbd/motorSupport.dbd
tandem_DBD += $(MOTOR)/dbd/devSoftMotor.dbd
tandem_DBD += $(STD)/dbd/epidRecord.dbd
tandem_DBD += $(STD)/dbd/std.dbd
tandem_DBD += $(IOCSTATS)/dbd/devIocStats.dbd
tandem_DBD += stream.dbd
tandem_DBD += tandem_seq.dbd
tandem_DBD += $(MODBUS)/modbus.dbd
tandem_DBD += $(TSDAQCTL)/tsdaqctl.dbd
tandem_DBD += $(MOTOR)/dbd/devMclennanMotor.dbd     # ADDITION 1
# Add all the support libraries needed by this IOC
tandem_LIBS += anunuclear djrestore modbus
tandem_LIBS += asyn std calc seq pv motor softMotor devIocStats stream streamSynApps
tandem_LIBS += tsdaqctl
tandem_LIBS += Mclennan                            # ADDITION 2
# tandem_registerRecordDeviceDriver.cpp derives from tandem.dbd
tandem_SRCS += tandem_registerRecordDeviceDriver.cpp
tandem_SRCS += pwm.st
tandem_SRCS += linac-resonators-conditioning.st
tandem_SRCS += msnics_wheel.st
tandem_SRCS += injecting_magnet.st
tandem_SRCS += bigblue.st
tandem_SRCS += foil_changer.st
tandem_SRCS += cup_metering.st
tandem_SRCS += beam_config.st beam_on.st
tandem_SRCS += supere-target-loader.st
tandem_SRCS += supere-solenoid.st
tandem_SRCS += silverpak-23ce.st
tandem_SRCS += linec_target_ladder.st
tandem_SRCS += linac_ac1.st
# turn on snc debug messages
SNCFLAGS += +d
# Build the main IOC entry point on workstation OSs.
tandem_SRCS_DEFAULT += tandemMain.cpp
tandem_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#tandem_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
tandem_LIBS += $(EPICS_BASE_IOC_LIBS)
tandem_SYS_LIBS += curl z
seq_DIR = $(INSTALL_LIB)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
The result of a compilation via make is an error while trying to build the x86 version, with output:
/usr/bin/g++ -o tandem -Wl,-Bstatic -L/home/peter/epics/trunk/base/lib/linux-x86 -L/home/peter/epics/trunk/modules/asyn/lib/linux-x86 -L/home/peter/epics/trunk/modules/calc-2-8/lib/linux-x86 -L/home/peter/epics/trunk/modules/devIocStats/lib/linux-x86 -L/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86 -L/home/peter/epics/trunk/modules/seq-2-0-12/lib/linux-x86 -L/home/peter/epics/trunk/modules/std-2-8/lib/linux-x86 -L/home/peter/epics/trunk/support/anunuclear/lib/linux-x86 -L/home/peter/epics/trunk/support/djrestore/lib/linux-x86 -L/home/peter/epics/trunk/support/modbus/lib/linux-x86 -L/home/peter/epics/trunk/support/tsdaqctl/lib/linux-x86 -L/home/peter/epics/trunk/tandem/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/base/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/modules/asyn/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/modules/calc-2-8/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/modules/devIocStats/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/modules/seq-2-0-12/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/modules/std-2-8/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/support/anunuclear/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/support/djrestore/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/support/modbus/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/support/tsdaqctl/lib/linux-x86 -Wl,-rpath,/home/peter/epics/trunk/tandem/lib/linux-x86       -m32    -Wl,-rpath,/lib/i386-linux-gnu -Wl,-rpath,/usr/lib/i386-linux-gnu            tandem_registerRecordDeviceDriver.o pwm.o linac-resonators-conditioning.o msnics_wheel.o injecting_magnet.o bigblue.o foil_changer.o cup_metering.o beam_config.o beam_on.o supere-target-loader.o supere-solenoid.o silverpak-23ce.o linec_target_ladder.o linac_ac1.o tandemMain.o    -lanunuclear -ldjrestore -lmodbus -lasyn -lstd -lcalc -lseq -lpv -lmotor -lsoftMotor -ldevIocStats -lstream -lstreamSynApps -ltsdaqctl -lMclennan -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -Wl,-Bdynamic -lcurl -lz -lpthread   -lreadline -lm -lrt -ldl -lgcc
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(drvPM304.o): In function `motor_init()':
drvPM304.cc:(.text+0xa1f): undefined reference to `motor_task(thread_args*)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(drvPM304.o):(.data.rel+0x24): undefined reference to `motor_send(mess_node*, driver_table*)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(drvPM304.o):(.data.rel+0x28): undefined reference to `motor_free(mess_node*, driver_table*)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(drvPM304.o):(.data.rel+0x2c): undefined reference to `motor_card_info(int, mess_card_query*, driver_table*)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(drvPM304.o):(.data.rel+0x30): undefined reference to `motor_axis_info(int, int, mess_axis_query*, driver_table*)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(devPM304.o): In function `PM304_end_trans(motorRecord*)':
devPM304.cc:(.text+0x21): undefined reference to `motor_end_trans_com(motorRecord*, driver_table*)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(devPM304.o): In function `PM304_start_trans(motorRecord*)':
devPM304.cc:(.text+0x591): undefined reference to `motor_start_trans_com(motorRecord*, board_stat**)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(devPM304.o): In function `PM304_init_record(void*)':
devPM304.cc:(.text+0x5d4): undefined reference to `motor_init_record_com(motorRecord*, int, driver_table*, board_stat**)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(devPM304.o): In function `PM304_init(void*)':
devPM304.cc:(.text+0x634): undefined reference to `motor_init_com(int, int, driver_table*, board_stat***)'
/home/peter/epics/trunk/modules/motorR6-5-2/lib/linux-x86/libMclennan.a(devPM304.o):(.data.rel+0x34): undefined reference to `motor_update_values(motorRecord*)'
collect2: ld returned 1 exit status
make[1]: *** [tandem] Error 1
make[1]: Leaving directory `/home/peter/epics/trunk/tandem/tandemApp/src/O.linux-x86'
make: *** [install.linux-x86] Error 2
Everything inside the motor module directory builds fine.  Any help is much appreciated.
Regards
Peter
Dr Peter Linardakis
Accelerator Research & Development Engineer
Nuclear Physics | Research School of Physics and Engineering
Australian National University
e: [email protected]
p: +61 2 6125 2862
w: http://physics.anu.edu.au/nuclear/
Re: Problem linking Mclennan stepper motor libraries into x86 IOC app Andrew Johnson
Prev: Re: error of beacon Scott Baily
Next: Re: USB asyn driver Vikram Bhagat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: USB asyn driver ulrik.pedersen
Next: Re: Problem linking Mclennan stepper motor libraries into x86 IOC app Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
