1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: check what is caput doing
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 10 Sep 2014 11:02:30 +0200
On 10/09/2014 10:30, [email protected] wrote:
The outuput of cainfo is
LEBT:LEBT:PS:STH1:OPER:CurrSP
     State:            connected
     Host:             10.30.0.10:5064
     Access:           read, write
     Native data type: DBF_DOUBLE
     Request type:     DBR_DOUBLE
     Element count:    1
Full access - no firewall and/or access security issue. Good.
What value are you trying to write to which field of what record type?
This is the current setpoint of a power supply.
The IOC db file contains this information
record(ai,"LEBT:PS:STH1:OPER:CurrSP"){
   field(INP,"LV:LEBT:PS:STH1:OPER:CurrSP CP")
   field(DESC,"PS EXT Voltage")
   field(DESC, "LEBT STH1 Current SP")
I guess that I am trying to change the INP field which has no access
permission according to the Record Reference Manual, isn't it?
In this case how is possible that the value can be changed with the CSS GUI?
Should have the record a VAL field?
This input record is configured (through its INP setting) to get its value from LV:LEBT:PS:STH1:OPER:CurrSP, whenever that record's value changes.
Writing to the INP field will change the record's configuration to point to another source for the value.
Writing to the VAL field is probably closer to what you want, but still - your caput changes the value and processes the record, then during that processing the record does what it is configured to: it reads the value from the configured location LV:...:CurrSP.
Bottom line:
If you configure your input record to pull its value from another location, you cannot change the value by writing to it, and vice versa.
Hint:
Maybe the simulation mode (again: described in the Application Developers Guide and the Record Reference Manual) is able to achieve what you want. It allows you to switch your input record into simulation mode (.SIMM), where it will not use the configured INP link, but a special simulation link or value (.SIOL) to fetch its value.
Sorry if they are trivial questions; but I new to EPICS.
I would suggest participating at a training. The next public one is held as part of the EPICS collaboration meeting end of October in Saclay (Paris), France. There are also people and companies that can provide in-house training, if that is more appropriate.
Good luck!
~Ralph
check what is caput doing zunbeltz
Re: check what is caput doing Ralph Lange
Re: check what is caput doing zunbeltz . izaola
Prev: Re: check what is caput doing Burkhard Kolb
Next: Problems with synApps and Epics using Cygwin on Windows Vlad Andrei Rusu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Device Support Options for NI RIO Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
