1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn and stringin records
To: <[email protected]>, <[email protected]>
Date: Sat, 8 Nov 2014 15:59:00 +0000
Hi Mark,
I noticed that interruptCallbackWaveform() will add a NULL terminator if less than "nelm" characters are copied, but callbackWfRead() etc. do not do this. I enclose a patch that adds this feature to them too, and also a couple of "paranoid" string termination checks elsewhere that may or may not be useful/necessary
Freddie
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 07 November 2014 23:34
> To: Akeroyd, Freddie (STFC,RAL,ISIS); '[email protected]'
> As I was fixing the string termination problem that Freddie found, I
> discovered that there was another problem with interruptCallbackSi and
> interruptCallbackWaveform in devAsynOctet.c.  Neither of those functions
> was locking the record with dbScanLock while the record fields were being
> modified.  All of the other asyn device support does correctly lock records
> during the interrupt callbacks.  The problem was only in devAsynOctet.c.
> I have fixed both problems and committed to SVN.  The fixes will be in the
> R4-25 release of asyn.  Meanwhile you can get them here:
> https://svn.aps.anl.gov/epics/asyn/trunk
> Mark
> From: Mark Rivers
> Sent: Friday, November 07, 2014 10:26 AM
> To: '[email protected]'; [email protected]
> Hi Freddie,
> This is the current code that handles the interrupt callbacks for the stringin
> record.  You are definitely correct that it does not guaranteed that the string
> is null terminated.
> This is the code for periodic reads. It does guarantee that the string is null
> terminated.
> static void callbackSiRead(asynUser *pasynUser)
>     devPvt         *pdevPvt = (devPvt *)pasynUser->userPvt;
>     stringinRecord *psi = (stringinRecord *)pdevPvt->precord;
>     size_t         nBytesRead;
>     asynStatus     status;
>     size_t         len = sizeof(psi->val);
>     status = readIt(pasynUser,psi->val,len,&nBytesRead);
>     psi->time = pasynUser->timestamp;
>     if(status==asynSuccess) {
>         psi->udf = 0;
>         if(nBytesRead==len) nBytesRead--;
>         psi->val[nBytesRead] = 0;
>     finish((dbCommon *)psi);
> This is the code for I/O Intr scanned records. It does NOT guarantee that the
> string is null terminated.
> static void interruptCallbackSi(void *drvPvt, asynUser *pasynUser,
>        char *data,size_t numchars, int eomReason)
>     devPvt         *pdevPvt = (devPvt *)drvPvt;
>     size_t         num;
>     pdevPvt->gotValue = 1;
>     num = (numchars>=MAX_STRING_SIZE ? MAX_STRING_SIZE : numchars);
>     strncpy(psi->val,data,num);
>     psi->udf = 0;
>     if(num<MAX_STRING_SIZE) psi->val[num] = 0;
>     /* Set the status from pasynUser->auxStatus so I/O Intr scanned records
> can set alarms */
>     if (pdevPvt->status == asynSuccess) pdevPvt->status = pasynUser-
> >auxStatus;
>     scanIoRequest(pdevPvt->ioScanPvt);
> I propose to change this to:
>     size_t maxChars = sizeof(psi->val)-1;
>     if (numchars > maxChars) numchars = maxChars;
>     strncpy(psi->val,data,numchars);
>     psi->val[numchars] = 0;
>     psi->udf = 0;
> can set alarms */
> >auxStatus;
> Mark
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of [email protected]
> Sent: Friday, November 07, 2014 9:58 AM
> To: [email protected]
> Subject: Asyn and stringin records
> Hi,
> I have come across a difference in behaviour with asyn and the EPICS
> stringin record (asyn 4-22 / base 3.14.12.2 / win64) that occurs when the
> value received by the driver happens to be larger than the stringin
> maximum size. A record was changed from "periodic scan" to "I/O Intr"
> resulting in a crash due to a strcpy() (in monitor() from stringinRecord.c of
> base) being unable to find a NULL terminator and thus overwriting memory.
> Looking at devAsynOctet.c  it seems that stringin records that are
> periodically scanned are always guaranteed to have a NULL terminated
> value, whereas ones processed via interruptCallbackSi() are NULL
> terminated only if the data received is less than 40 characters long (I noticed
> that in base 3.14.12.4 the stringinRecord.c monitor() routine now uses
> strncpy() and so does not require NULL termination). For my case I've just
> added NULL termination for "I/O Intr" too, but from looking at the stringin
> record reference manual page I wasn't sure if the ori!
>  ginal I/O Instr stringin behaviour was actually more correct?
> Regards,
> Freddie
> Scanned by iCritical.
Index: devAsynOctet.c
--- devAsynOctet.c	(revision 2455)
+++ devAsynOctet.c	(working copy)
@@ -508,11 +508,12 @@
     asynStatus     status;
     size_t         nBytesRead;
     long           dbStatus;
-    char           raw[MAX_STRING_SIZE];
-    char           translate[MAX_STRING_SIZE];
+    char           raw[MAX_STRING_SIZE+1];
+    char           translate[MAX_STRING_SIZE+1];
     dbStatus = dbGet(&pdevPvt->dbAddr,DBR_STRING,raw,0,0,0);
+	raw[MAX_STRING_SIZE] = 0;
     if(dbStatus) {
         asynPrint(pasynUser,ASYN_TRACE_ERROR,
             "%s dbGet failed\n",psi->name);
@@ -573,12 +574,23 @@
     return initDrvUser((devPvt *)pso->dpvt);
+/* implementation of strnlen() as i'm not sure it is available everywhere */
+static size_t my_strnlen(const char *str, size_t max_size)
+    const char * end = (const char *)memchr(str, '\0', max_size);
+    if (end == NULL) {
+        return max_size;
+	} else {
+        return end - str;
 static void callbackSoWrite(asynUser *pasynUser)
     stringoutRecord *pso = (stringoutRecord *)pdevPvt->precord;
-    writeIt(pasynUser,pso->val,strlen(pso->val));
+    writeIt(pasynUser,pso->val,my_strnlen(pso->val, sizeof(pso->val)));
     finish((dbCommon *)pso);
@@ -601,12 +613,16 @@
     waveformRecord *pwf = (waveformRecord *)pdevPvt->precord;
     asynStatus     status;
     size_t         nBytesRead;
+    char           *pbuf = (char *)pwf->bptr;
     status = writeIt(pasynUser,pdevPvt->buffer,pdevPvt->bufLen);
         status = readIt(pasynUser,pwf->bptr,(size_t)pwf->nelm,&nBytesRead);
         pwf->time = pasynUser->timestamp;
-        if(status==asynSuccess) pwf->nord = (epicsUInt32)nBytesRead;
+        if(status==asynSuccess) {
+		    pwf->nord = (epicsUInt32)nBytesRead;
+			if (nBytesRead < pwf->nelm) pbuf[nBytesRead] = 0;
     finish((dbCommon *)pwf);
@@ -631,10 +647,12 @@
     asynStatus     status;
     size_t         nBytesRead;
     long           dbStatus;
     if(dbStatus) {
             "%s dbGet failed\n",pwf->name);
@@ -647,7 +665,10 @@
@@ -672,10 +693,14 @@
     size_t         nBytesRead;
     asynStatus     status;
     status = readIt(pasynUser,pwf->bptr,pwf->nelm,&nBytesRead);
RE: Asyn and stringin records Mark Rivers
Asyn and stringin records freddie.akeroyd
Prev: RE: Asyn and stringin records Mark Rivers
Next: Re: CA reference manual mystery function: ca_sg_pend Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Asyn and stringin records Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
