What does
which xsubpp
give on your system ?
Mac OS X 10.9 has this:
/usr/bin/xsubpp
(And I have perl from /usr/bin/perl):
which perl
/usr/bin/perl
Does it help to adjust your $PATH to use perl from /usr/bin ?
On 02/12/14 09:14, Wang Xiaoqiang (PSI) wrote:
Unfortunately Perl failed when building 3.15.1 on OS X Yosemite, with PERL 5.16.3 installed by MacPorts,
$ which perl
/opt/local/bin/perl
$ $ perl -V:bin
bin='/opt/local/bin';
The xsubpp program should be /opt/local/bin/xsubpp.
$ ls -l /opt/local/bin/xsubpp*
lrwxr-xr-x 1 root admin 11 Oct 18 22:41 /opt/local/bin/xsubpp -> xsubpp-5.16
-rwxr-xr-x 1 root admin 4576 Oct 18 22:40 /opt/local/bin/xsubpp-5.16
This creates the following warning,
$ perl -CSD /usr/bin/xsubpp -typemap /opt/local/lib/perl5/5.16.3/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
perl version 5.16.3 can't run /usr/bin/xsubpp. Try the alternative(s):
/usr/bin/xsubpp5.16 (uses perl 5.16)
/usr/bin/xsubpp5.18 (uses perl 5.18)
Run "man perl" for more information about multiple version support in
Mac OS X.
Maybe one should not hardcode perl’s binary path, but derive it from perl config:
PERLBIN = $(shell $(PERL) ../perlConfig.pl bin)
XSUBPP = $(firstword $(wildcard $(PERLBIN)/xsubpp $(EXTUTILS)/xsubpp))
This fixes my problem.
Best
Xiaoqiang
On 01 Dec 2014, at 19:22, Andrew Johnson <[email protected]> wrote:
Thanks guys. I committed Michael's version and added a patch to the
3.14.12 Known Problems page.
In RHEL 6 /usr/share/perl5/Extutils/xsubpp exists as a soft-link to
/usr/bin/xsubpp, while earlier Perl versions have it only in Perl's
ExtUtils directory.
- Andrew
On 12/01/2014 07:23 AM, Michael Davidsaver wrote:
A more (OS) portable way to accomplish this
XSUBPP = $(firstword $(wildcard /usr/bin/xsubpp $(EXTUTILS)/xsubpp))
On 12/01/2014 05:43 AM, Torsten Bögershausen wrote:
I tried to compile EPICS under "Scientific Linux release 7.0 (Nitrogen)"
It failed, because xsubpp is no longer here:
but found here:
/usr/bin/xsubpp
Thanks to Götz, who helped me debugging the error and finding a fix.
For now I added a shell script to see where xsubpp is.
The following applies to base-3.15.1-rc1 (but the problem is in older
bases as well)
Does this sound reasonable, or are there better ways ?
diff --git a/src/ca/client/perl/Makefile b/src/ca/client/perl/Makefile
index 6ae32dd..516e494 100644
--- a/src/ca/client/perl/Makefile
+++ b/src/ca/client/perl/Makefile
@@ -54,10 +54,11 @@ include $(TOP)/configure/RULES
ifdef T_A
EXTUTILS = $(shell $(PERL) ../perlConfig.pl privlib)/ExtUtils
+ XSUBPP = $(shell if test -x /usr/bin/xsubpp ; then echo
/usr/bin/xsubpp ; else echo $(EXTUTILS)/xsubpp ; fi)
%.c: ../%.xs
$(RM) $@ $@_new
- $(PERL) $(EXTUTILS)/xsubpp -typemap $(EXTUTILS)/typemap $< >
$@_new && $(MV) $@_new $@
+ $(PERL) $(XSUBPP) -typemap $(EXTUTILS)/typemap $< > $@_new &&
$(MV) $@_new $@
$(INSTALL_PERL_MODULES)/$(PERL_ARCHPATH)/%: %
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
- Re: xsubpp moved under Sscientif Linux 7.0 Wang Xiaoqiang (PSI)
- catools (caget/caput/camonitor) and locale settings from the environment Goetz Pfeiffer
- Re: catools (caget/caput/camonitor) and locale settings from the environment Torsten Bögershausen
- xsubpp moved under Sscientif Linux 7.0 Torsten Bögershausen
- Re: xsubpp moved under Sscientif Linux 7.0 Michael Davidsaver
- Re: xsubpp moved under Sscientif Linux 7.0 Andrew Johnson
Re: Does EPICS has defects? Ralph Lange
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
