1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: xsubpp moved under Sscientif Linux 7.0
To: Torsten Bögershausen <[email protected]>
Cc: Epics <[email protected]>
Date: Tue, 2 Dec 2014 09:43:28 +0000
$ which xsubpp
/opt/local/bin/xsubpp
Of course reordering the $PATH also fix the problem.
I am sorry for hijacking this email thread.
> On 02 Dec 2014, at 09:50, Torsten Bögershausen <[email protected]> wrote:
> What does
> which xsubpp
> give on your system ?
> Mac OS X 10.9 has this:
> /usr/bin/xsubpp
> (And I have perl from /usr/bin/perl):
> which perl
> /usr/bin/perl
> Does it help to adjust your $PATH to use perl from /usr/bin ?
> On 02/12/14 09:14, Wang Xiaoqiang (PSI) wrote:
>> Hi,
>> Unfortunately Perl failed when building 3.15.1 on OS X Yosemite, with PERL 5.16.3 installed by MacPorts,
>> $ which perl
>> /opt/local/bin/perl
>> $ $ perl -V:bin
>> bin='/opt/local/bin';
>> The xsubpp program should be /opt/local/bin/xsubpp.
>> $ ls -l /opt/local/bin/xsubpp*
>> lrwxr-xr-x  1 root  admin    11 Oct 18 22:41 /opt/local/bin/xsubpp -> xsubpp-5.16
>> -rwxr-xr-x  1 root  admin  4576 Oct 18 22:40 /opt/local/bin/xsubpp-5.16
>> This creates the following warning,
>> $ perl -CSD /usr/bin/xsubpp -typemap /opt/local/lib/perl5/5.16.3/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
>> perl version 5.16.3 can't run /usr/bin/xsubpp.  Try the alternative(s):
>> /usr/bin/xsubpp5.16 (uses perl 5.16)
>> /usr/bin/xsubpp5.18 (uses perl 5.18)
>> Run "man perl" for more information about multiple version support in
>> Mac OS X.
>> Maybe one should not hardcode perl’s binary path, but derive it from perl config:
>>   PERLBIN = $(shell $(PERL) ../perlConfig.pl bin)
>>   XSUBPP = $(firstword $(wildcard $(PERLBIN)/xsubpp $(EXTUTILS)/xsubpp))
>> This fixes my problem.
>> Best
>> Xiaoqiang
>>> On 01 Dec 2014, at 19:22, Andrew Johnson <[email protected]> wrote:
>>> Thanks guys. I committed Michael's version and added a patch to the
>>> 3.14.12 Known Problems page.
>>> In RHEL 6 /usr/share/perl5/Extutils/xsubpp exists as a soft-link to
>>> /usr/bin/xsubpp, while earlier Perl versions have it only in Perl's
>>> ExtUtils directory.
>>> - Andrew
>>> On 12/01/2014 07:23 AM, Michael Davidsaver wrote:
>>>> A more (OS) portable way to accomplish this
>>>> XSUBPP = $(firstword $(wildcard /usr/bin/xsubpp $(EXTUTILS)/xsubpp))
>>>> On 12/01/2014 05:43 AM, Torsten Bögershausen wrote:
>>>>> Hi,
>>>>> I tried to compile EPICS under "Scientific Linux release 7.0 (Nitrogen)"
>>>>> It failed, because xsubpp is no longer here:
>>>>> but found here:
>>>>> /usr/bin/xsubpp
>>>>> Thanks to Götz, who helped me debugging the error and finding a fix.
>>>>> For now I added a shell script to see where xsubpp is.
>>>>> The following applies to base-3.15.1-rc1 (but the problem is in older
>>>>> bases as well)
>>>>> Does this sound reasonable, or are there better ways ?
>>>>> diff --git a/src/ca/client/perl/Makefile b/src/ca/client/perl/Makefile
>>>>> index 6ae32dd..516e494 100644
>>>>> --- a/src/ca/client/perl/Makefile
>>>>> +++ b/src/ca/client/perl/Makefile
>>>>> @@ -54,10 +54,11 @@ include $(TOP)/configure/RULES
>>>>> ifdef T_A
>>>>>   EXTUTILS = $(shell $(PERL) ../perlConfig.pl privlib)/ExtUtils
>>>>> +  XSUBPP = $(shell if test -x /usr/bin/xsubpp ; then echo
>>>>> /usr/bin/xsubpp ; else echo $(EXTUTILS)/xsubpp ; fi)
>>>>>   %.c: ../%.xs
>>>>>        $(RM) $@ $@_new
>>>>> -       $(PERL) $(EXTUTILS)/xsubpp -typemap $(EXTUTILS)/typemap $< >
>>>>> $@_new && $(MV) $@_new $@
>>>>> +       $(PERL) $(XSUBPP) -typemap $(EXTUTILS)/typemap $< > $@_new &&
>>>>> $(MV) $@_new $@
>>>>>   $(INSTALL_PERL_MODULES)/$(PERL_ARCHPATH)/%: %
>>> People everywhere confuse what they read in newspapers with news.
>>> -- A. J. Liebling
catools (caget/caput/camonitor) and locale settings from the environment Goetz Pfeiffer
Re: catools (caget/caput/camonitor) and locale settings from the environment Torsten Bögershausen
xsubpp moved under Sscientif Linux 7.0 Torsten Bögershausen
Re: xsubpp moved under Sscientif Linux 7.0 Michael Davidsaver
Re: xsubpp moved under Sscientif Linux 7.0 Andrew Johnson
Re: xsubpp moved under Sscientif Linux 7.0 Wang Xiaoqiang (PSI)
Re: xsubpp moved under Sscientif Linux 7.0 Torsten Bögershausen
Prev: Re: xsubpp moved under Sscientif Linux 7.0 Torsten Bögershausen
Next: RE: edm questions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: catools (caget/caput/camonitor) and locale settings from the environment Torsten Bögershausen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
