Hi Freddie,
Note that for the gateway part, I published a fix release 2.0.5.1 on
Monday, which contains the same or equivalent fixes for everything you
have in your patch. Thanks, anyway - sorry that you had to go through
the same mess...
As for the caPutLog part, that's not me. I agree with Andrew that
removing the epicsShareAPI would be the way to go. Are the maintainers
listening? Please?!
Cheers,
~Ralph
On 12/12/2014 16:26, [email protected] wrote:
Hi Ralph,
I've compiled 2_0_5_0 both with and without the caPutLog support on windows 7 x64, but have only checked the non-caPutLog version so far at runtime. I enclose the small changes that were required to the caPutLog and gateway code to build it, I hope to try the caPutLog support in the near future.
Freddie
-----Original Message-----
Sent: 04 December 2014 13:58
To: EPICS Tech-Talk
Subject: CA Gateway 2.0.5.0 released
All,
I just uploaded a minor release of the CA Gateway [1], tagged 2.0.5.0 -
featuring
* 3.15 compatibility: compiles against 3.14.11+ and 3.15.1
* Support for the CaPutLog module to log CA put operations, using the
same library as the IOC [2]
(thanks to FRIB for this contribution)
It seems that Windows builds have been broken for a while - they still are.
If you are in production, I would think the update is of low priority,
unless you want to use the CA Put Log support.
Source tar available at
https://launchpad.net/epics-
gateway/trunk/2.0.5.0/+download/gateway2_0_5_0.tar.gz
Next things in the Gateway pipeline include:
- Make it a standard self-contained EPICS TOP module
- Deprecate the built-in watchdog/restart in favor of using procServ [3]
- Add integration testing (SLAC started working on this)
- Support DBE_PROPERTY event flag (SLAC started working on this)
- Resurrect Windows build (volunteers?)
Cheers,
~Ralph
[1] http://launchpad.net/epics-gateway
[2] http://www-csr.bessy.de/control/SoftDist/caPutLog/
[3] http://sourceforge.net/projects/procserv/
- RE: CA Gateway 2.0.5.0 released freddie.akeroyd
- Re: CA Gateway 2.0.5.0 released Benjamin Franksen
- CA Gateway 2.0.5.0 released Ralph Lange
Re: caQtDM on ipad zhuangjian
<2014>
2025
<2014>
2025
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
