1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Gateway 2.0.5.0 released
To: <[email protected]>
Date: Mon, 15 Dec 2014 18:10:28 +0100
Am Freitag, 12. Dezember 2014, 20:42:16 schrieb Ralph Lange:
> Hi Freddie,
> Note that for the gateway part, I published a fix release 2.0.5.1 on
> Monday, which contains the same or equivalent fixes for everything you
> have in your patch. Thanks, anyway - sorry that you had to go through
> the same mess...
> As for the caPutLog part, that's not me. I agree with Andrew that
> removing the epicsShareAPI would be the way to go.  Are the maintainers
> listening? Please?!
Hm, that would be me I guess. So is removing epicsShareApi the consensus or
not? If there are inconsistencies between .c and .h files in caPutLog I will
fix them in favor of whatever you think is more useful.
Cheers
Ben
> On 12/12/2014 16:26, [email protected] wrote:
> > Hi Ralph,
> > I've compiled 2_0_5_0 both with and without the caPutLog support on
> > windows 7 x64, but have only checked the non-caPutLog version so far at
> > runtime.  I enclose the small changes that were required to the caPutLog
> > and gateway code to build it, I hope to try the caPutLog support in the
> > near future.
> > Regards,
> > Freddie
> >> -----Original Message-----
> >> From: Ralph Lange [mailto:[email protected]]
> >> Sent: 04 December 2014 13:58
> >> To: EPICS Tech-Talk
> >> Subject: CA Gateway 2.0.5.0 released
> >> All,
> >> I just uploaded a minor release of the CA Gateway [1], tagged 2.0.5.0 -
> >> featuring
> >>    * 3.15 compatibility: compiles against 3.14.11+ and 3.15.1
> >>    * Support for the CaPutLog module to log CA put operations, using the
> >> same library as the IOC [2]
> >>      (thanks to FRIB for this contribution)
> >> It seems that Windows builds have been broken for a while - they still
> >> are.
> >> If you are in production, I would think the update is of low priority,
> >> unless you want to use the CA Put Log support.
> >> Source tar available at
> >> https://launchpad.net/epics-> >> gateway/trunk/2.0.5.0/+download/gateway2_0_5_0.tar.gz
> >> Next things in the Gateway pipeline include:
> >>    - Make it a standard self-contained EPICS TOP module
> >>    - Deprecate the built-in watchdog/restart in favor of using procServ
> >>    [3]
> >>    - Add integration testing (SLAC started working on this)
> >>    - Support DBE_PROPERTY event flag (SLAC started working on this)
> >>    - Resurrect Windows build (volunteers?)
> >> Cheers,
> >> ~Ralph
> >> [1] http://launchpad.net/epics-gateway
> >> [2] http://www-csr.bessy.de/control/SoftDist/caPutLog/
> >> [3] http://sourceforge.net/projects/procserv/
"Make it so they have to reboot after every typo." -- Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: CA Gateway 2.0.5.0 released Ralph Lange
RE: CA Gateway 2.0.5.0 released freddie.akeroyd
Prev: Re: pyepics "Virtual circuit disconnect" CA.Client.Exception Andrew Johnson
Next: Fwd: Undelivered Mail Returned to Sender Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA Gateway 2.0.5.0 released freddie.akeroyd
Next: Re: CA Gateway 2.0.5.0 released Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
